J
jmcelroy
Hi all,
Based on one of my previous threads I have experimented with mics, mic placement, some minimal technique changes and a bit of room treatment when recording acoustic guitar in my little home studio. As I mentioned in that thread, I have recorded a little doodling with the guitar in hopes that someone would be willing to read a description of my setup, listen to a sample recording, and suggest changes or simply make comments about what they readhear.
I am using the following setup:
Guild GAD-30r acoustic guitar
Medium plastic $0.25 pick (fat round back end used)
Shure SM81-LC mic 17 inches away pointed just slightly behind the bridge (no attenuation or filtering)
Fatman 2 tube pre-amp, compressor is NOT engaged, nor is the filter
Center of a 12'x12' room with 8' ceiling
Mattress up against the back wall
very small amount of acoustic foam on front wall (just enough to sit behind the monitors)
No processing at all
The little doodle is located here:
www.kingswhenlucid.com/thanksForTheHelp.wav
And, just to be sure that nobody finds me disrespectful, I posted this here instead of in the mp3 clinic forum because it's not really about the recording so much as it is the recording *technique*. Therefore I found this thread more appropriate.
Thanks for any and all help, advice, and commentary!!
--John
--John
