R
RejectionNinja
But its still different than what a power attenuator does (although I don't think that's what your arguing anyways).
We're in agreement there - said so myself.
I just don't see the benefit of using anything that does't allow you to actually PUSH the power tubes. Even if you have your master volume turned way up, if you're only feeding it a small signal, you're not pushing the power tubes into breakup or saturation. You're just adding another volume knob before the power section. I can see how this would be useful for an amp that doesn't have a channel volume, but I can't see the use for any other amp.
It may sound different than simply turning down the master but its still not going to sound the same has having the master wide open, and feeding the power section a hot signal. There's just no replacing that sound.
All you're getting with this device is still the same amount of power amp distortion (or less) than you'd get without it. And power amp distortion is what keeps us tube fanatics drooling![]()
Well, what you're getting is a ton of headroom.
You're also gaining very fine control over your output volume which is sorely lacking in many amps. Just want to reiterate that some individual examples of the Peavey Classic series are louder than bedroom levels with the post amp on 0.
If your goal is to send a hotter signal to the power amp, these boxes are clearly the wrong solution.
