R
RejectionNinja
The short answer:
A master volume knob reduces the signal sent to the power section.
Adding a volume knob in the effects loop duplicates the master volume function. It will behave exactly as a master volume does, with the exact same benefits and downfalls, because it is exactly the same thing.
Putting the amp's master on 10 and turning the knob in the loop halfway* is the same as having no knob in the loop and the master halfway down.
*"Halfway" meaning a 50% attenuation of signal, the physical positions of the knobs may well differ.
This is all basically true.
However, if you have a tube amp and you can't turn up the existing "post amp" or "master volume" knob past 1 (out of 12) because it is deafening, you're not really using the amp properly. An audio taper pot doesn't *JUST* decrease the perceived volume, it also affects the tone.
If you install one of these volume knobs in the effects loop, you can open up that master volume knob (say 50%) and control the overall volume in the effects loop (say 50%) and you'll have a much better sound.
It's still the same level signal reaching the power amp (on average), but it's not being choked to death by a frequency-ignorant barely-open volume knob. The whole conversation about reactive dummy speaker loads applies to any resistor in the signal chain, to some degree.
*SHEW*. THAT was what I was trying to express in this whole thread and it got way out of hand. My apologies.
It doesn't matter if it's on your strat, your preamp, or your master volume knob - a variable resistor at 5% open affects your tone, and usually in a bad way.
If you're normally running that master volume at decent settings (like anything from 3-10) then this volume knob in the effects loop isn't going to do much for you.
I only jumped into this thread in the first place because my friend hated his Classic 50 because it was so loud that it was basically useless indoors. He got one of these volume knobs and the amp went from worthless to priceless in his opinion. Under the right circumstances, they're very useful.
