Tascam MA-AD8 (tdif / analog converter)
  • Thread starter Thread starter frederic
frederic
frederic
Now that I have an Alesis AI-3, I no longer need the Tascam MA-AD8 unit. This unit has pre-amps similar in design to the TM-D8000 and TM-D4000 which are fairly nice pre's actually. The unit wasn't used all that much and it's in nice shape, except for minor rack rash and even that is fairly minimal. This unit was installed with rubber washers on the rack screws, unlike a lot of my gear. Boxed and ready to go. Power cord is part of the unit, I don't have the manual, but if it isn't obvious in how to utilize it, the PDF is still available from Tascam.
$225 shipped (ground) to the continental US, additional shipping for other countries, locations and planets.
Specs:
http://www.expandore.com/product/TASCAM/Converter/MA-AD8.htm
General
Microphone inputs (1-8)
XLR, balanced
Nominal impedance
2.4 kOhm
Overload indicator
Lights at 3 dB below digital full-scale level
TRIM range
42 dB
PAD attenuation
22 dB
Input level (TRIM max.)
-56 dBu
Input level (TRIM min.)
-14 dBu
Signal-to-noise ratio (IHF-A, at 150 Ohm)
>86 dB (TRIM max.)
>94 dB (TRIM min.)
Crosstalk between adjacent channels (10 kHz)
>80 dB
Frequency response
20 Hz – 22 kHz (+0.5 dB, -1 dB, Fs = 48 kHz)
Total harmonic distortion
<0.03%, at 1 kHz, nominal level, TRIM min.
Digital output format
TDIF-1
Sampling frequencies
44.1 kHz, 48 kHz (±6%)
A/D converter resolution
20 bit
Clock source
D I/O1, D I/O2, WORD IN
LOCKED indicator
Lights when valid clock source received at selected input
WORD CLOCK IN
BNC, 75 Ohm
WORD CLOCK THRU
BNC, 75 Ohm, auto-terminated
Power supply
230 V AC, 50 Hz
Power consumption
10 W
Dimensions (W x H x D)
483 mm x 48 mm x 210 mm
Weight
2.2 kg
i would like to buy ur ma ad8
send info on how I cam buy this tascam ma ad8 send info to zlive69@hotmail.com
and or call 323 495 8042 leave on wht must be done to buy this call and leave voice mail
could not get into expandor or wht ever its called would like to buy this now if its in good working order so call we will do pay pal
The original post is 5 years old--so I doubt it's still for sale.
