K
Kerose
it seems like the only way i can get my levels up to around 0db when recording vocals is by turning it up to the point where it records a lot of static too, what am i doing wrong
what do you mean by losing headroom, anything below -12 in sonar is hardly audible, i have got to be missing something very fundamentalDbop has it. Your levels should be around -18db or so. Anything beyond -12 is just causing you to lose headroom for your mixing stage. Background noise depends a lot on your recording location and acoustic treatment of that location.
well what interface are you using, what mic, etc. You could have a weak mic or not so great preamps. Any combination like that will show in the output.
What I meant about losing headroom is the idea way to track is around the -18db level. This gives you plenty of "headroom" to use in the mixing and mastering stages of recording. For instance if you track at near clipping, then you have nothing left when it comes to mix everything down, you'll be clipping by that point.
Well you do need that headroom for a proper mixdown later on. I'm no expert some I'm sure others would be more helpful but let's call your "beats" your backing track. When you import that onto track 1 lets say you should leave the fader at unity "0" and have all your other tracks go on that. During your mix down you bring those levels up due to adding comp, limiters, etc. to the master and each track (plugins)
The mic you have is decent so I'm sure the problem probably isn't the mic. I know nothing about the interface or how good the preamps in it are. Someone that uses it could chime in and be more helpful on that. If you're truly barely hearing anything at proper -18 to -12db tracking levels then something somewhere is wrong. Start simple and look at obvious things like a bad mic cable, whether the interface is supplying the right amount of phantom power or not, etc.
I can't say for sure if running it like that would cause problems. When I "track" meaning record my levels never really go about -18db and I can hear everything just fine. When you mix everything down you hear all those things because you're playing them through monitors that are specified just for hearing all the little nuances. This is why I said you definitely got to have a problem somewhere in your setup.
You seem to be discribing background noise that is present and relative to the volume (at the mic) with your voice- This relative amount of noise won't change with how hot you track, or whether you turn it up before or later in Sonar. If that's the case you need to get away from the noise, get some isolation, or get closer/sing louder... i can record at a level that will trigger sonar at about 0db and will be loud without clipping, but then i also pick up the "static", if i record quiet enough so that sonar shows no background noise, and i also can't hear any, wehn i record my vocals, i can hardlly hear myself and sonar doesn't even hardly register a waveform cuz it's so quiet
If you can't hear your vocals at -12, you have everything else WAY too loud.what do you mean by losing headroom, anything below -12 in sonar is hardly audible, i have got to be missing something very fundamental
Kerose said:sorry, maybe one last poke here,
if i have my beat/instrument track at 0, and i am recording my vocal track at -12db, how the heck can you hear what you are singing...
Sorry to chime in here and I know this has been written about loads here but can I just get it clear:
When everyone says 'track at -18db' etc does that mean the track volume bar (I'm using GarageBand) is set at that level and I should make sure the levels when I record don't go above -18db or that I should just make sure my levels don't go above -18db without physically adjusting the track level bar? Does this make sense? Because there's a volume set bar on the track, right? So I can pull that down to -18db but still get the levels going up to -0db...I'm confused...
(Sorry to add a question to someone else's post but it's quite relevant to me too.)
intomusic
Recording levels: http://www.massivemastering.com/blog/html/blog_files/Proper_Audio_Recording_Levels.htmlwhat do you mean by losing headroom, anything below -12 in sonar is hardly audible, i have got to be missing something very fundamental
