C
chamelious
www.thesunexplodes.com
Hmm im begining to think something must be wrong somewhere. Im talking 9 on both channel and master volumes, and this is a high gain setting too. heres the amp specs:
Specifications
Power Output (RMS) 60W into 4, 8 or 16 Ohms
Power Requirement 120 Watts at rated supply voltage
Speaker Configuration 2 x 12"
Line Input Impedance 1M Ohm, Level 100mV to 1V
Line Output Impedance 4.7k Ohms, Level Nominal 0dBu (Speaker Emulated)
EQ Traditional passive, interactive tone control network providing basic classic guitar tonal adjustment
Effects Send Impedance 4.7k Ohms, Level Nominal 0dBu
Effects Return Impedance 50k Ohms, Level 0dBu adjustable
Pre-Amp Tubes 4 x 12AX7 with DC heaters for low-noise
Output Tubes 6 x EL34 fixed bias
H x W x D (mm) 570 x 700 x 280
Specifications
) at about 40% of total volume...
