PhilGood
Juice box hero
I have been rebuilding some mics left over from parts and circuits left over from Soundelux. I ran into a road block. The machinist making the bodies got one done for one of the e47 (U47 copy) mics. I bought aluminum pipe that was 2.5" outer diameter and 2.25" inner diameter. The 2.25" inner diameter fits the frame perfectly so I had him machine one full solid body to match the U47 dimensions. It looks great!
However, the labor involved in machining a single piece brought the cost of the body up to $300 each. I still have 3 more e47s to do and 13 iFet7s to do. I can't afford it at $300 a pop. So I thought I will just have him machine the simple parts for the basket and get them welded together and then find tubing that will make the sleeve and attach with the 3 screws that hold the basket to the frame.
Here's the problem: No one seems to make pipe that is 2.375" (2 3/8") outer diameter and 2.25" inner diameter. It needs to be aluminum because that's what Neumann used for the sleeve of the U47.
Anyone know of a place to get this size tubing? I am at a complete LOSS!
Thanks in advance if anyone knows.
