V
vegafreak
Will styrofoam or cardboard egg cartons work better. Anyone know?
try a foam mattress pad.
they make those eggcrate foam mattress pads, looks identical to expensive diffusers.....
much cheaper, although im sure the material is not the same....
but close...
http://www.nextag.com/egg-crate-foam-mattress-pad/search-html
Bad, bad, bad idea.......
really? why?
the lock out studio (for jamm rooms) i go to in Burbank, CA has them hung on the interior walls. i asked the guy what is was (cause it looked like eggcrate foam mattress pads)....
and sure enough.....he confessed it was.
cheap bastard.....
dumb bastard.....
You remember the physics fairly well, but if my memory serves half as well, you are kinda throwing two parts absorption and one part diffusion into one pot there.If I recall my old physics, the actual mechanism that attenuates sound is when the energy passes from one medium to another. A little bit will be absorbed, a little bit reflected, and a lot converted to heat as it moves the medium. The greater the difference in densities of the mediums, the greater the attenuation. The more mediums the sound has to pass through the greater the attentuation.
These can be easily made by buying yourself a 2x2, cutting it into many irregular lengths from 1" to a few inches and then gluing them together in a checkerboard pattern with some carpenter's glue.
G.
Good point. I'm sure that there's math to ensure a high degree of randomness; i.e. that if you have a block of length x and a block of length y, you don't want to have them spread z inches apart because they will just wind up reflecting back at the same angle, and stuff like that. Also the size of the squares themselves may play a part in bandwidh limiting the effectiveness of the diffusion, I would guess. I'm sure such math could be found on the Internet.Not to poo poo on a pretty good post, but I was under the impression that it was WAY more complex than that. I thought there was some kinda crazy algorithm that determined the length of each block. Or am I mis-remembering?
My fault for not reading the whole tread from the beginning, Chili. Sorry 'bout that. Not that I was criticizing to begin with or anything, I didn't mean to single you out.Thanks G. Nah, I wasn't referring to diffusion at all. I know it's totally different from absorption. I was replying to bkkornaker's post about the mattress foam and why it's not a good candidate from sound absorption. Then I just threw out useless information on why some stuff works and others don't. Essentially, hijacking the thread.![]()
No Hijacking.
I'll report you to a mod.
G.
I think the short answer is, "It depends...."Bringing this back to the original post (so I'm not hijacking anymore), I don't think the OP needs diffusion. Based on his other threads, he's got a small room and according to Ethan, absorption is the best method tuning the room. Do I have that right?
Go back and re-read the last few posts, it's all pretty much spelled out. But in short, absorption stops sound from reflecting by absorbing it's energy, diffusion doesn't stop reflection but it diffuses the reflected energy in many different directions, rendering it fairly harmless without absolutely getting rid of it. Absorption deadens sound, diffusion de-focuses it.Title= "for home made diffuser...."
so what are we talking about here? diffusion? or absorption?
and what the heck is the difference (if any)?
