TyphoidHippo
1Trillion K Platinum User
Here's a comp, I hesitate to post these because my kit is crap and I'm not a drummer, but hey, I can beat out quarter notes . . . I can't hit as hard as a real drummer though.
One channel is the K-Micro and the other is another condenser microphone of the same basic type. Don't try to guess which, because I won't tell you, and your guess will likely be wrong anyway.
I'll post which channel is the K-Micro this evening.
Both mics about 1" from each drum. The last sample is a front side kick with the pillow removed, and I'm beating it as hard as I can with a mallet. Not a particularly musical sound, but I like it for testing drum mics because a) it's really loud, and b) it's a bit easier to hear distortion--if present--on the peak.
Preamp is ART Digital MPA, which can take severely loud input levels with no trouble. No pad used on either mic. Each channel was normalized (the K-Micro started off about 4dB louder), but no other processing other than .mp3 conversion.
Well... the left side sounds much cleaner, brighter, and more "airy". The transients seem to have more balls and don't linger around after their time is done.
The right side sounds dead and mushy...and distorted on the transients, which, I guess, in turn, accounts for the mushiness. Based on the earlier descriptions of the K-Micro, I am guessing that this is it...
Clearly a big difference, and just based on these clips, I can see the mic on the left being much, much more useful for recording drums...or anything, really. So if it's not the K-Micro, I hope you change your mind and tell us what it is. (I also hope it's something awesomely ridiculous like a 22 cent electret soldered to a coat hanger duct-taped to the input on the preamp. I love it when that happens
Both mics were mounted in the same clip, with their capsules less than 1/2" apart, 1" from the top side of each drum (beater side on the kick).
Then I told her my Apple ][ only had 48K of memory, and 16K of that was reserved, so effectively you could do about 6 seconds of 8 bit/4kHz audio, and still leave enough memory to run your program . . . floppy disks were too slow to dynamically retrieve audio, as a hard drive can do . . .
