R
RRuskin
Rick Ruskin
1.5 mil tape will not harm the machine. It simply won't meet published specs which were measured using 1 mil. BTW - what is the exact context of the "1.5 mil tape not recommended" statement?
Tascam says.
Use of the recommended tapes in the chart below will ensure optimum performance from your 22-2. the use of tapes other than those that we recommend for the 22-2 will produce results that may lie outside the limits of our published specifications. The use of 1 1/2 mil tape is not recommended. If you have a special reason or need to use a tape other than one of those recommended, we suggest you ask your dealer to readjust the bias and eq.
It is a good professional practice to standardize on one particular tape.
Tapes listed are]
Ampex 357 407
Maxell ud, ud-xl
Scotch 227, 207
Sony DUAD
TDK ADUA(L series)
On the tape list in the A-3300SX owners manual (listing what bias/eq setting to use for various brands of tape) column heading says "1 mil base tapes -- recommended for 2 track and 4 track decks" then listing various tape brands. And the other column heading "1 1/2 mil base tapes -- recommended for 2 track decks only"
How much out of specs are we talking about? the published spec +/- 3dB is 40Hz - 24kHz, assuming that it rolls off steeper as the overall freq response is stated at 30-28 at 7.5 ips. This is as good or better than 48kHz digital, with out the brick walls at either end. I don't know the specs on teh 22-4, but assume they are similar to the 3300SX-2trk at 15 ips which has slightly better low freq response. Also, I'm assuming out of spec means I start to roll off sooner on the high end? Where does that roll off occur? I will likely be using dbx or Dolby both of which only claim a freq response up to 20kHz.
If I'm only slightly losing the extreme high end (which arguably contributes something so that I am one of those nuts that prefer analog to digital) am I going to notice?
Also, at one point I am certain I had the 3300 calibrated for Ampex 456 by a shop here in town.
And for part time use is wear something I should be concerned about?
