kojdogg
bollocks redux!
anyone using this setup? how much "whammy" action can you get without throwing your guitar way out of tune? i know it won't compare to a locking trem, but how close does it get?
Maybe he means a half-blocked vibrato rather than a full-floating one.Just looked at all three guitars I have with whammy (A Schaller, a Flloyd Rose, and a loose Bigsby copy) and I can not imagine what you mean by a "non-locking trem." To my eyes, a "locking trem," is a contradiction of terms- if the strings were locked at the bridge, you would have ZERO whammy movement. On the Rose, the trem and bridge move as a unit, whereas on the Schaller and Bigsby copy, the trem does move the strings over the bridge saddles. Which one (if either) is a "locking trem??"
And I don't EVEN want to know about ermghoti's "non-mocking" tuners...
Further to that: there are double and single locking trems.A Floyd Rose is a locking trem. The string ends are clamped (locked) into place, and can not shift at all, regardless of what gymnastics are applied to the bar. a typical Fender trem is non-locking. The string ends are held in position by the tension of the tuned string. If detuned slack with a dive, they will wander around a bit, and may or may not return to the exact same position. I don't find it a big problem, but I also haven't encountered a non-locking trem with the range of a Floyd type.
Don't make me sic my mocking tuners on you.
Hendrix tuned on the fly because he used guitars which went out of tune with the abuse but were still pretty much top of the range at the time.Ha! You call those tuners! I call them a poor excuse for not being able to tune on the fly. What use would Jimi have for mocking tuners, he tuned on the fly all the time and mostly just played out of tune and bent each note to pitch. I got your mocking tuners right here with yo momma's mocking tuners. Had enough yet or should I mock you further?
Hendrix would probably be playing Parker Fly guitars and modelling amps if he was alive today, he was using cutting edge stuff back then, why not now... yes with locking tuners and locking trems and still with a more open mind than yours.
There was in the mid to late 60's - it was the best you could get with a trem that wasn't a bigsby. Not so much nowadays obviously.hmm... i wont hypothesize about what mr hendrix might or might not have been using lately were he still alive and playing.
but there is nothing particularly cutting edge or high tech about a mid to late 60's straight off of the rack stratocaster with the strings on upside down.
Locking tuners are better than non-locking tuners, but if your doing a lot of dive bombs and heavy trem yanking you really need to get a Floyd and a locking nut. That's the only thing that will consistently stay in tune with use that heavy.
You don't like the Lace Sensors?the tuning stability couldnt make up for the "ultra" shittiness that exuded from the lace sensor pickups.
I've got those in my '91 Strat Plus (the one I referred to in my post above) and I really like 'em, especially for clean and barely crunchy stuff. They're pretty low output, though.
