BeniRose
I have this old mix that I'm trying to play around with, since I've learned quite a lot since the first time I mixed it. I went to go take a listen to the drums, and apparently I had no idea what I was doing because they sound awful. I still tried to work with that I have and started mixing them. I noticed that there's way too much bleed on all the mics, which I can take care of using noise gates on most of them, but my main concern is that the overheads are too busy. I tried starting the mix with the overheads, but then when I brought in the the snare top and bottom mics, I could hardly tell the difference, since they're so prominent in the overheads. Is there a way I can tune them back a bit so they aren't so loud in the OHs?
