Other than the fact that the Protools drivers can be problematic with other drivers, I have done so fine after wrestling with them for a while. If you're going to use the same hardware for both (likely Maudio I suppose), then it should go easier. They';re just drivers after all. If you're going to use different hardware for each as i did, expect a little wrangling with keeping the PT drivers from pooping all over your other drivers.
