G
gjukonline
Right..*sigh*..
It's a long post..I Know..But please please please help me out i've been waiting 9 weeks for this to come together! It's my second thread on these forums..I keep encountering problems with my set-up.
PLEASE PLEASE PLEAAASE If You Could Help Me I Would Be SOO Thankfull
my aim is to record urban vocals over a soundtrack. Simple...right?
Not for me
I am just starting out. So please don't beat me up for my equipment. It's just to get me off the marker and to find out if it's something i want to do in the long run
microphone: Behringer B2-Pro (large diaphram condensor)
Pre/mixer: Behringer Xenyx 802 (phantom power, EQ, FX)
leads: TRS from "main out" of mixer to an adaptor for soundcard
Soundcard: Creative Soundblaster Audigy SE
Now. Initially i bought my microphone and mixer based on a friends set up. His sounds perfect and warm in similar use.
Mine however, does not. He uses the old B2 (not pro) and a tapco mix60 mixer (£15GBP cheaper than my Behringer one)
his sound card is onbard i assume (not sure & neither is he). So i would have thought my "Audigy SE" would be better than his too.
So why does my recordings sound worse if theoretically (spelling) My set-up is of better quality..?
My Set-up is crisp and warm when hooked up as:
Microphone > Mixer > Studio Headphones
So my guess is there is no faults with the mixer and microphone.
It all goes wrong (i'll explain soon) when i rig it to my computer, so I'm almost positive it's either the soundcard or settings somewhere.
NOW HERES THE BIT I NEED HELP WITH DESPERATELY
Whilst I'. record into DAW's (more than one attempted) it all sounds good.
I can hear myself clearly through my headphones and i can hear the soundtrack at the same time.
However, when i playback the recording along side the soundtrack, the recording seems to delay a few Milisecs and after about 10-15secs it becomes more noticable, causing the perfect recording i have done...to run off beat after a while
( I might have just been able to say, "Latency", But as I'm still a novice I wanted to explain what was hapenning thouroughly so i don't buy stuff / change stuff i don't need. )
The other issue I'm having is the recording sounds nice and loud whilst recording..but when i playback it isn't that loud and i don't want to have to boost / dynamicly (spelling) adjust EVERY recording i do.
I understand that ASIO drivers are important for recording and my "SoundBlaster" supports "ASIO4ALL" but I'm guessing it's universal & may not be that effective.
I also understand that "SoundBlasters" are frowned upon by many recording artists..Lucky It's Only £20 I Spent On It.. I know people..should have researched..my Bad..
SOOO.... I need some advice on what to do to fix the delay & volume problem and it sounds simple but I can't get it.
Is it possible to sort delay with a "Soundblaster"?
do i need to buy a firewire interface?
could i go:
mic > mixer > interface > DAW, if i bought an interface?
is there any other suggestions / ways to sort it out?
& finally..how could i fix / improve my low volume after recording issue?
Congratulations if you made it to the end of this thread LOL
please help me if you can. I would appreciate it so much and if your suggestion works i'm sure I could send you my album when It's recorded
Thanks again kind people
love for you all
xxx
Not for me
could i go:
love for you all
xxx
