F
Funkylb
I also posted this query in the Midi Mania discussion, but my problem also falls under the aegis of this forum.
Hey folks! I've got a question about using 2 midi devices with an audio card that only has one set of MIDI I/O inputs. I have the Lexicon Omega, a Yamaha S90 keyboard and I want to buy the Akai MPD24 Midi Pad Controller all going into Acid Pro 6.0. The Omega only has a single set of Midi I/O. I want to use my keyboard for triggering samples from SampleTank loaded as a VSTi into Acid and then use the Akai pad to trigger drums using EZDrummer loaded as a VSTi into Acid. Let me say that I know how to use VSTi(s) in Acid etc...I know how to use SampleTank and EZDrummer with a single midi instrument (my keyboard). I'm wondering how do I use both midi devices independently when I only have a single set of Midi I/O on my audio card (the Lexicon)? In other words I ONLY want the Akai pad controller to trigger drums and I ONLY want my keyboard to do all other instruments. I was reading about the master--> slave config using the MidiThru port on my keyboard, but I don't really get it 'cause it seems the two devices are then not independent of each other. Any help is appreciated.
LB
LB
