Can't find self made presets!
  • Thread starter Thread starter Bassmusic808
B
Bassmusic808
Hello. Ok, here is the problem in a nutshell. Had to have my computer repaired, so they wiped out my hard drive and sent it back to me fixed. So, I did have to reinstall my adobe 3.0, which i did make a back up of. I basically copied the entire Adobe folder to another computer before I sent it in for repair. However, after looking in that folder, i can't find where the presets are saved?? Anyone know where they are hiding? I have a folder that says presets but its empty.. But, it was from the same folder i copied before i sent my computer in and I had been using self made presets..(the factory ones don't even show up, but I can use them).. suggestions??
-Derrick
-Derrick
C:\Program Files\Adobe\Audition 3.0
just check there...just incase.
Yah. I did check there. I have a bunch of other files there, but none of them look like they are presets. Unless they are saved in a file called something else? Like, say you wanted to share a preset you made with someone else, how would you do that?
It maybe in your account settings. I think its something like
C:\Documents and Settings\[username here]\Application Data\Adobe\Audition...
If that is the case though, the files disappeared with your old HD. :(
