K
keat_taylor
how bad of an idea is it to use large diaphragm condensers as cymbal mics as compared to using a 57... those are my options... begin.
I have four jacks to work with so I'm going as follows
snare - sm57
kick - B52A
overheadL - Nady SCM900
overheadR - Nady SCM900
into a Fostex MR8-HD
thoughts, ?'s concearns
Just make sure you treat your overheads as "OVERHEADS"...not "CYMBAL MICS".![]()
if it's more of a heavier rock sound I'm looking for I'll copy the OH tracks, strip the cymbals from them, and then EQ the toms to bring them up in the mix.
LDCs work great as OH mics in Recorderman or Glyn Johns setups. I use LDCs all the time, if it's more of a heavier rock sound I'm looking for I'll copy the OH tracks, strip the cymbals from them, and then EQ the toms to bring them up in the mix.
I never thought of that. That's brilliant!!! Sort of gives you separate tom tracks without close micing the toms.
So, if I understand you correctly, you simply mute or erase everything except when the toms play on the doubled OH track???
Erasing everything is best. I've found that if you try and EQ out the high end, it just makes the cymbals sound dull and muddy when the "tom" tracks are combined with the overheads. Sort of like if you submix your drum tracks and then do parallel compression, you can just tell it doesn't sound right past a certain point in the higher frequencies.
It's a bit time consuming, but worth it. I usually will make a stereo .wav of the OH mics with them panned out to about 80 on each side, then strip out everything but the toms, then mix those in with the OH mics on mixdown and EQ/compress to taste. It doesn't sound EXACTLY like close micing, but since I only have the 4 inputs on my Firebox, it helps the toms cut through. Once you get going with the stripping, you can usually eyeball about 75% of the .wav and strip out thing by looking at the peaks and seeing where the toms come in.
What about the decay tails on the cymbals that are contemporaneous with the toms? It seems you might have to resort to some unnatural cuts and fades. Maybe since it's a doubled track that gets sorta buried enough that it's a not issue?
(I just wanted to use "contemporaneous.")
I was thinking that. But then, when you think of it, you usually crash AFTER a tom roll, so I'm hoping it won't be a problem all the time. You might have some left over from a ride cymbal, if that's where the drummer was riding, before the roll. But that shouldn't be too loud, most of the time.
