dickiefunk
Hi. Has anyone on here tried making a DIY mic stand mountable SE Reflexion Filter type thing? Please could you share your DIY booths and advice.
Thanks
Thanks
Just build 2 2'x2' rigid fiberglass panels held together with hinges, then work out a way of having it the height you need(copy the real traps design, sorry EthanHi. Has anyone on here tried making a DIY mic stand mountable SE Reflexion Filter type thing? Please could you share your DIY booths and advice.
Thanks
)What, foam?those may not do much, as i think the material they used is probably made more for diffusion then absorbtion.
No i think they'd work fine, but rigid fiberglass panels would probably work better, especially at lower frequencies.This will be good for high frequencies, but not great low-mid. Rigid fiberglass panels would be better, imo.Here's mine:
http://www.palmcitystudios.com/timobrien/music/soundbooth/simplesoundbooth.html
NOT a total isolation booth, but it works for me and is cheap and storeable....
Probably the bigger one. With the smaller one, you'd have to get really close to it. It would be cheaper though.Thanks for the replies and sharing your ideas! Which design would you suggest as being most effective for recording vocals out of the 2 I posted? I would really like to stick to a stand mountable design if possible.
Especially since it was a blind purchase and I had no idea if it would be useful or not. That's why they invented eBay though, right?
I couldn't help showing of the reflection filter that I made. I used PVC piping to construct a holder that attaches to the mic stand. It's nice and stable and works like a charm....
The cardioid pattern is mainly unidirectional with a null directly behind it.
Wouldn't it be more useful to have gobos behind the source to block reflections off of the back wall?
At 1 KHz maybe, but lows and low mids are more omnidirectional. See Figure 8 (and several others) in this PDF from the Shure web site:
http://www.shure.com/idc/groups/public/documents/webcontent/pdf_ea_dual_diaphragm_mics.pdf
I can't speak for other products by other companies, but when you put a RealTraps PVB behind the microphone, the sound of your voice is absorbed before it has a chance to get out into the room in the first place. Hearing is believing, and these two "slide show" videos prove the point:
RealTraps - PVB Demo (Kelly)
RealTraps - PVB Demo (Doug)
--Ethan
