P
pezking
OK so you may have seen my previous thread asking for opinions and your feedback was appreciated. I have gone ahead and discussed it with my parents (it's their garage!) and it's getting closer to being given the green light.
Basically I've drawn a quick plan in PSP. I'll now try to explain it as best I can.
The garage is a detached single brick structure, with an apex roof. Currently there is no ceiling, but joists at approx 2.4m up. There are existing windows in the left wall, and a door in the top wall. The bottom wall currently has two 2.2m square up and over style garage doors. The plan is to brick up these walls and insert windows and a door as shown. The reason for this is that my Dad doesn't like the idea of having a plain brick wall, and wants to keep up the appearance of the property.
The plan on the inside is to put up stud walls around the perimeter of the garage with half inch plasterboard, with rigid mineral wool insulation slabs behind. Ideally I'd like to have plasterboard either side of the framework but this may be practically difficult, so I may go with two pieces on the inside only unless this is a bad idea? I would attach half inch plasterboard to the joists, with two layers of cross laid rigid mineral wool above.
The windows will be "framed". This is for appearance reasons (my Dad again) and also to let some natural light in. Obviously I will have a second window inside (flush with the plasterboard) which will not be able to be opened, unless I can think of a good way of doing it... I will also hang heavy drapes.
I plan on using fire doors, or building my own doors from two layers of plywood with mineral wool between.
I realise that the partition may not be best down the middle for acoustic reasons, however it's necessary, as the partition will be of some load bearing. It is also an easier and cheaper option.
Right now the floor is a solid concrete base. I won't be leaving it bare. I like the idea of having laminate flooring (appearance mainly, and perhaps good reflections???), although carpet is an option too. Both options would use a thick underlay. Perhaps I could have laminate in the control room and carpet in the live room?
I also realise that the rooms have two dimensions which are nearly a multiple of the other. The only thing I can think of is to shorten the rooms at the top wall, and have a corridor/cupboard there. This could also allow me to store my computer and amps, though to be honest they don't need their own room.
I plan to use any left over mineral wool for acoustic treatment, as well as the 20 or so rockwool slabs and acoustic foam I already have.
Any thoughts on my idea and plans?
The only specific Qs I have are:
1. Would you have the control and live rooms the way round I have shown? If not, why not? (I figured I'd rather have fewer windows in the control room)
2. Laminate flooring, or carpet, or both? Why?
But please feel free to chip in with any other comments.
Thanks for reading this far!
Pez
Pez
