JTC111
Active member
So, um, in answer to your original question ...
The more expensive comps generally sound better.
You're welcome.
My kingdom for a smartass filter!
You're welcome.
I'm not a tech-head, so perhaps my attempts at articulating this are falling short. Let me start over...
On tracks where the acoustic guitar alternates between softer fingerpicked passages and louder strummed passages, it's impossible to find a set volume level that works on both ends. If I set the gain high enough to make the softer parts come through well, it's too hot for the louder parts, and vice versa.
Because the guitar on my music is not just out in front but will often be the only instrument, I worry that playing with the faders from the get go will give me a less natural sounding track than if I apply a minimum, but sufficient, amount of compression during the initial recording and then use volume automation during mixing.
As for the 'noise' I referred to, I mean this: imagine recording something at a very low volume and then gaining it up to a sufficient level. Along with the music, you also get the noise from the equipment (mics, pres, convertors, etc.).
You're welcome.
Ouch!!Again, I think you are not really understanding the fundamentals of what a compressor does. I understand what you think you are using it for, and yes, it will work to accomplish what you are doing, but it will also cause the issues you are citing as reasons to not automate, to worsen, not be better. A comp will bring the noise up, and the actual guitar sound down, no? Automation will bring the noise AND the guitar sound up. Automation will be heard far less than compression, unless you do it wildly - but wild compression is pretty obvious as well. I am not trying t rail you, I just want to understand how a compressor is better in this situation. In fact, I would love to be shown to be wrong, and learn a new trick. I love new tricks!![]()
Compressors demystified!![]()
I'll try to do it your way as well and compare, but I'm not even sure how to do it with only one set of hands which will be busy on the guitar. It bears repeating... I'm not a tech-head. I'll have to give it some thought.
I have recorded a lot of acoustic instruments though, and never had the dynamics be much of a problem - dynamics are OK to have.
Also, if you record at 24 bit, I can't imaging getting enough volume difference from clipping to inaudible on an acoustic guitar, or the guitar player wouldn't even be able to hear what he was playing.....I'll try to do it your way as well and compare, but I'm not even sure how to do it with only one set of hands which will be busy on the guitar. It bears repeating... I'm not a tech-head. I'll have to give it some thought..
But if your comparing to Commercial releases... the only way for me to get close is by Compressing. Personally I think Compression is the Secret for great Mixes. & it's the hardest thing to get to Know.
I don't really EQ much either... No "Wild" Eq at least. I usually just Eq the Bottom and low mids with a Cut and if I touch the upper mids or Highs it might be a bit of a boost to bring a instrument out in the mix. In general I don't do much more than -5 or +5 depending. Even a +1.5 can help bring something out. IMO. i.e. on my last project there was a banjo in one of the tunes and the guy wanted it a little louder... too me it had enough weight (body) in the mix and didn't really need to be Louder... so I EQ'd +2 (somewhere, can't remember 3k-5k ?) and it came out and he say's that's perfect.
As far as Compression... personally I do like more of a Live sound (Dynamics). But if your comparing to Commercial releases... the only way for me to get close is by Compressing. Personally I think Compression is the Secret for great Mixes. & it's the hardest thing to get to Know. 10 years ago I told a Engineer friend of mine Compression is something I just don't quite get... and it's only really been in the last 3 or 4 that I feel I'm getting it. I think your right about Too Much Comp on Home recordings. I think too many people want to or need to Hear It and that is usually too much. That's why I call it a Secret. The whole pumping and breathing with Kick and snare is something I'm still working on.
I also look at it like this...
When your recording a Good Song none of this really matters.
But when you record a Bad song and someone says "Man that sounds Good!" You know your doing something right.
B.
Daisy... You been Blowing Chessrock?
I don't want to hear it at all. But I also don't want people to have to adjust and readjust their volume when listening to a song. My first cd got some buzz and some airplay. I think I have a chance to make some real headway with the next cd as the songs I've written are stronger and I have some pretty well-known names (at least well-known in folk circles) making guest appearances.
Automation is done after the Fact... lay down your tracks, then in your DAW you can Automate the level of the track... to bring the Volume level up or down.
What program are you using?
I just listened to a couple of your tracks on your website. Di you record those? I thought they sounded pretty good. I think you could let the AC guitar have some more dynamics though, but that is a matter of taste. I wouldn't worry so much about getting them super loud. If you can swing a decent mastering job, I think they will do amazing things for your tracks. They are decent as they stand, and if your witting is better, and your recording is even a little bit better, you should have a pretty good CD.![]()
Having no high end compressors to compare the focusrite to, I have no idea as to what the differences might be. I'm assuming there must be some fairly significant difference otherwise why would someone pay $3000 for a compressor as opposed to $300.
well- you kinda dodged the question. you should know what you're doing with the 300 dollar compressor before you move on to the 3000...and i mean no offense by saying it. if you want a strict comparison a good one to follow is: you can screw up tracks with both cheap and expensive - the higher end one's can sound even worse doing the wrong things.
if you want an answer - get to know what your 300 dollar compressor is before asking what the 3000 dollar one is.
now if you want a more expensive compressor for your acoustic and vocals it sounds like an la3 may suit ya. from reading some critiques to your tracks - it sounds like you may not need one either...
also your noise issue is really a playing, proper gain staging and/or background noise issue. your compressor will bring up the same noise and your tracks will be the same weight more or less.
good luck!
Mike
Okay..so I didn't read thru the whole thread but I will still throw my .02 in...High end compressors are leaps and bounds better than low end stuff..They are way better at preserving the frequency of the material..not perfect mind you but what they do with the freq response has a vibe to it. I own 2 high end units and when I got them I imediately said.."A HA!"...With a good mic, pre and compressor it becomes relatively easy to get a smoothe, polished and translatable sound. As I upgraded my chains I think the jump to professional compressing made the biggest, most noticaeable impact on the sound. I will now sit here while people attempt to assail me with tails of great mixes and sounds they have gotten with this or that cheap gear. More power to you. I have been doing this for 20+ years and have owned just about every prosumer box as I moved up the ladder. Here is the advice nobody likes to heed. IF you want to pursue a professional career as an AE or are simply trying to get the "pro sound"...be patient,save your clams and buy good gear. Worst case if you want to quit you can sell it as pro gear rarely loses any value provided you care for it. Now donning my flameproof suit.......
Cheers,
Ray
