SouthSIDE Glen
independentrecording.net
It is a point that once you get it, it's obvious, but it seems to take a lot for some people to get itThanks Glen. I left that last part off b/c i've said it (as have so many others) so many times over the years around here that i figured it was obvious at this point.![]()
. Even now in this thread we still have people asking other people for advice on whether specific monitors are "any good". Such questions are about as meaningful as asking whether such and such is a good color for their shirt. Evenrybody is going to have a different opinion, none of them very relevant.Now, it might be relevant to to report that speaker X seems to have a bump here, rolls off uqickly there, or speaker Y has crisper than mormal sibilants but muddy-sounding mids as compared to speaker z. But this would require two things: first knowing that the ears of that reporter aren't tricking them (a la the flat=hyped route, for example) and that they can discern such references, and second that the reporter leaves such descriptions technical and objective. "Speaker A" sounded great but speaker B didn't" applies only to that person and no one else, and is useless advice.
Yes it is. There's a difference, though, between speakers between being entirely incapable, and speakers being deficient.CoolCat said:To mix on speakers, that are incapable of producing lows, is like blindly making judgements isn't it?
Even the most ardent of NS10 supporters probably wouldn't suggest using them to mix, for example, a piece that relies heavily upon a syncopation of a couple of different 808-style bass drop rhythm tracks. They just don't go low enough. Even 824s are only going to give you so much of that picture. Ideally, one would want to be in a subwoofer-equipped CR to get the full picture.
That said, however, what NS10s will do is tell you when those 808s are messing with the rest of your mix and casing trouble on lesser repro systems. That is, the NS10s may be able to tell you that, "hey, I can't pronounce those drops very well, but listen to how bad they sound here. If you can get them so they don't mess me up, you might be OK." Alternately, the NS10s will also tell you if it can't repro those drops, whether the mix sounds lacking because it relies too much upon those drops to sound good.
This is what they mean when they say "if it sounds good on an NS10, it'll probably sound good everywhere". It doesn't necessarily mean that one can necessarily do an extended-spectrum mix on them and be able to trust the edges to be sweet, but rather that one can do a more conventional rock/pop mix and keep the edges from being sour. and that the main frequencies are at least OK.
And remember; you probably won't find many classical recordings mixed on NS10s, and those dance or hop recordings that do use bass drops and such were probably augmented by subwoofers regardless of their main monitors.
G.
. Not much time for mixing a session or anything serious. Made in Norway speakers....haha, I laugh whenever I read the bone heads dissing the China made on these, what a mental pile of shit.
