N
notCardio
I walk the line
that can be run stereo, splitting the cab in half?
the only other consideration is the impedance of the speakers--- basically only an issue with tube amps.
a
Actually there is an Issue with Impedance with solid state Amps, Some SS Amps can not handle Loads under 4 ohms so if you have Two 4 ohm speakers with would be better to wire them in Series to get 8 ohms rather than in paralell for 2 ohms...
Also if you Have Two 8 Ohm speakers it would be better to wire them in Paralell for 4 ohms as you get much more power output at 4 ohms than at 16 ohms.....
Cheers
incidentally, it is a snap to rewire practically any cabinet. depending on the jack plate, you will need to (a) just rewire it, (b) drill a hole for the extra jack, or (c) replace the jackplate with a two jack model (you can wire for stereo yourself, even if the silkscreening says they are wired together (like from a cheap PA speaker). the only other consideration is the impedance of the speakers--- basically only an issue with tube amps.
a
right. i assumed that the OP would do at least cursory research before soldering in a random jack. minimum impedance values should be clearly listed on the amp(s), and it seems pretty reasonable that he would take this into account.
increasing impedance with a ss amp will make the amp run cooler as well as reduce output, as youve mentioned. and truly, decreasing the minimum impedance by half with many ss amps will very likely be "ok", at the expense of higher temps and presumably shorter lifespan. i still have a big-knobbed cs-800 amp that spent 15 years driving 2 ohm loads--still works fine. then again the thing might cook off in minutes, perhaps particularly if its origins are chinese. 'net is full of amp death accounts and recounts.
increasing impedance with some tube amps can be a big problem, as can decreasing it (though perhaps to a lesser degree of danger, within reason).
a
