Ethan Winer
Acoustics Expert
Hash? Where are you, Amsterdam????![]()
Heh.
I hold dither above the others because IME there does seem to be a "signal" there
Yes, there's a signal there all right, but masking makes it inaudible. Like the example I think I mentioned earlier of the piano tracks posted at Lynn Fuston's forum where the acoustic noise floor was around -70. Guys insisted they could hear the dither, even though it was 20 dB below the room noise. This is a huge factor! How many tracks has anyone here produced where the noise floor was anywhere close to -90 where dither operates?
I've put a test method on the table
Did I miss that? Which post number? Yes, please, let's do it! But the test must be such that people can't cheat. This is the main problem I see because people can subtract one file from another and isolate just the dither. And from that they can tell which of two test files is dithered and which is not with one more subtraction.
This is why I made my test file the way I did. If dither is switched on and off in the middle of a passage, and nobody can even tell where a switch occurs, I maintain that proves the dither was inaudible. Maybe only for that one music example and one dither flavor, but proven inaudible none the less.
I will side with you IF the results tell me to as long as you can say the same for me![]()
Hell, I would love to be proven wrong. Go for it guys!
--Ethan
(I'd be happy to discuss these points in another thread!
Further investigation of that phenomenon is required
