masteringhouse
www.masteringhouse.com
do you have another dither plug that you can use?
And I still don't understand the Apogee behavior. It was really strange, never seen that on any other track
Yeah, I've got WL's internal dither, which has a bunch of options. Never had to try it before thoughAnd I still don't understand the Apogee behavior. It was really strange, never seen that on any other track
I wonder if anyone can listen to a track and identify if bass traps are or are not being used in a room?
Either way, truncation artifacting does appear as extra information encoded within the signal and the noise
I often can! Seriously. A mix done in a poor room sounds much like listening in a poor room. You can hear some bass notes pop out, and others disappear, as the mix engineer applied EQ inappropriately not understanding that he was EQ'ing his room rather than the track.
I don't know how far away you are in PA, but if you'd ever like to visit me here in western Connecticut I'll be glad to test your dither awareness. $100 says you won't be able to tell which dither flavor is which if I play the tracks and you can't see which one is playing.
--Ethan
I can't agree that the effects cannot be measured and shown to be potentially audible.
it's common for listeners to select material that is technically inferior.
as a recordist, I can't presume that the listener will calibrate their monitors appropriately and never crank it.
here is a simple test file:
what is the cost to eliminate quantization distortion?
What if the room never needed bass traps to begin with?
I haven't developed the ability to name the flavors of dither by listening, only that I can hear a difference between them.
It would be cool to meet anyway
How far into PA are you? I'm barely more than an hour from the eastern PA border.
All I see is a 1 KB file that won't play in Windows Media Player or even load into Sound Forge.![]()
It downloads fine for me, it's a 16 bit mono .wav file, only 5 seconds . . . doesn't open in WMP but that's not a huge surprise. I can open it in Wavelab without trouble.We're going around in circles now, Ethan. I already said twice that I wouldn't take that bet any more than you would take the bet over which track was EQd and which one wasn't, and that that is a red herring of a test that is asking for the wrong answer.I understand what you're saying, but I still have $100 that says you can't pick out dithered versus truncated in a blind test. It's just too soft, and too well masked by the music.
I'm all for Internet myth bashing; I'm sure we'll be allies in this in other upcoming topics. but I'm afriad you're trying to through the baby out with the bath water on dither, Eth. This one is real.
Stick to trapping bass, Tom'll stick to mastering mixes, and I'll stick to bopping Dana Delaney, and everything will remain in balance.
G.
How do I find out how many traps I need for my room size? I don't mind making 20 of 'em ... room dim:
But what if I'm right about bopping Dana Delaney?But what if I'm right on this myth too?![]()
