liv_rong
Knows very little
I just moved as the title suggests. I saved every box for all of my recording gear luckily, so I figured everything would be safe.........but no. My uncle dropped my Sonic Maximizer 482, yes I know most do not like them. I use it for my acoustic chain, ovation-->samson c-valve-->sonic maximizer--> acoustasonic jr. This set up has been great for me, and I am pretty upset that its broken now. I had it in the box, with the foam and everything, I watched it fall and we joked about it being broken, I said not to worry I doubt its broken. This was two days ago.
I have everything hooked up again, and today after work I was testing everything. The maximizer will not power up. I tried a few plugs, and plugged other things into the same plugs and everything else works, so its not my power strip. So I took the unit apart to look to see if a solder broke, but everything looks fine.
Does anyone have any tips on what else I should look for?? Im guessing its just the power supply, but who knows. Any advice is much appreciated. Thanks you very much in advance.
If it doesnt pan out it pm you.
