ecktronic
Mixing and Mastering.
i still think my late 70's style mix is the best...
It definitely stands out from other mixes.
Eck
Your mix started out sounding great with just the guitar but when everything else came in you lost all the guitar and it got buried in the mix. It was also kinda heavy on the bottom from that point on and I could hear the compressor pumping about halfway through the song during one of the verses.
The vocals sounded a little loud in the mix but other than that it sounds real good. Nice job!So here is my try ........
Great recording and a great song.... thanks for the music !!!
Dirk
I think you have a dead link there. I can't get to it anyhow.Tough competition. Here's my try:
http://http://www.lightningmp3.com/live/file.php?fid=10607
Thanks NL5 for the great tracks.
I was gonna play with this over the weekend. I downloaded the .aif files but when I tried to import into SONAR it says that the files are not compatable with my current project settings. I'm set up for 44100 sampling rate with a bid depth of 16.
Supwiddit?
Heres my newest mix.
How do you feel about it?
If you had mixed it for me, I would be happier with this than your previous.
I this case, you should only mix for yourself since you do not have a client for influence.![]()
I do feel a lot happier with this mix although I can hear harsh distorted guitars which I will be tweaking.
Thanks, I took good info from you.
I think I got feedback from NL5 from my first quick mix saying that the band were not into the whole polished sound, so I changed my style to try and suit what the "client" wanted.
But I'm glad you critiqued my mix cause you gave me the confidence to make it sound closer to how I want it to sound.
Good luck with your mix.
Eck
It was pumping starting at 1:43 into the song but check this out as to why.I am interested in the pumping you hear. Please point to a time and section.
Nice mix, clean and well balanced. Not saying that it's a bad thing but I could hear the verb on the vocals.
This won't play for me for some reason I'm thinking it's corrupted. It also might be your use of the dash - in the file name, some coding will see that as a delimiter, or notHere is a vocal-down-version from the first mix ...
Dirk
This won't play for me for some reason I'm thinking it's corrupted. It also might be your use of the dash - in the file name, some coding will see that as a delimiter, or not![]()
