liv_rong
Knows very little
So I know i have asked multiple questions about the MOTU 8 Pre, and it appears I have run into a snag. I wanted to purchase the Motu and keep a few outboard mic pre's hooked up to it, then use either a mixer with direct outs or the behri ada8000 to be able to easily plug and unplug stuff on the fly without having to pull my rack out and go behind it. It seems that I cant even use outboard pre's with the Motu, unless i use a pre with lightpipe.
The inputs on the Motu are XLR/TRS, but if I run an outboard pre into the input on the Motu, wouldnt I be amplifying the signal twice, thus creating unpleasant hiss or other bad sounds?
I was also looking at the SM Audio 8 channel anolog to digital(lightpipe) box. at first it seemed ok, even though its cheap, but it had no pre amps. so I figured I could plug my outboards to that, then lightpipe to the Motu. But the inputs are not balanced.
Can anybody help clear this up? I have been reading and reading for weeks about all of my options, but I can not get a clear answer as to how use my outboard pre's with the Motu. Im sure this is a stupid question, but as you can see I am totally clueless
Thank you for your help, it is greatly appreciated!
Joe
Joe
