H
handy
Hey everyone, got a dumb question about my new firebox. I'm trying to run my Tech21 trademark 10 amp into it from an XLR out. The amp has a built-in modified sansamp GT2, which I figured could act as a preamp so I'm turning the gain on the firebox all the way down. Problem is I have to turn the volume up all the way on the amp to get anything. I'm wondering if it's OK to turn up the input gain on the firebox as well... or is this bad because there'll be too much signal after a preamp is boosting a preamp? it definitely sounds better after I do it, but will it damage anything if i keep it like that?
thanks
thanks
Big fan of this amp, the touch-sensitivity isn't quite as good as a good tube amp, but if they ever get that sorted out and drop the silly active EQ (or at least give you a passive option - sorry, pet peeve) I just might make the switch from tube to solid state.
