T
tddrummer
what is an interface? i read that you can use this instead of a and i dont think my sound card is good....also what does a preamp do?
An audio interface (sometimes called a sound card) gets audio from the outside world into your computer. Many audio interfaces (especially low-end ones) contain analog-to-digital (AD) and digital-to-analog (DA) converters, but some require external conversion. Many computer motherboards have a built-in audio interface, but these generally are built from the cheapest possible components; hence their poor overall quality.what is an interface?
A preamp boosts a low-level signal to a higher level. Most often they are used to connect a microphone's output to the "line" level needed for a typical line input.what does a preamp do?
You gots about the same setup as I's does.....I use the M-Audio Delta 1010LT.
I use the M-Audio DMP3.
HTH,
Don
You, me, and many others, I'd bet.You gots about the same setup as I's does.....
