TelePaul
J to the R O C
Guys how exactly does the nut come off the neck on an electric? I'm not gonna try it but was wodnering how it's done.
What guitar? Some require a slightly different approach. Then I'll let you into my little secretsGuys how exactly does the nut come off the neck on an electric? I'm not gonna try it but was wodnering how it's done.
And hows that replacement Tele coming on....
No do not do that. Yes it will come off but so might some other stuffI just whack 'em with a hammer.
Go ahead ..... try it ...... it'll be ok.
Yeh but people come here looking for advice and I'd hate it if...........Hopefully you know I was joking but just in case anyone might not:
The hammer whacking is not the correct technique for removing a nut!
DO NOT WHACK YOUR GUITAR WITH A HAMMER!!
There, I feel like I've done some good here.
You're right, of course ..... hard as it is to believe, some one might try it.Yeh but people come here looking for advice and I'd hate it if...........![]()
Don't even go there. I see the consequences everydayYou're right, of course ..... hard as it is to believe, some one might try it.
Tele nuts are most often set in a slot rather than the more typical butted against the fingerboard type. As such they need to come out side ways or straight up. The easiest way is to scribe the join at the finish with a sharp blade to avoid chipping the finish. I use a very wide pair of grips to try and lever them out at this point. Be careful you can shatter or chip the nut doing so and also chip the finish. If that fails a little gentle persuasion with a flat piece of wood at the end of the nut and a light tap will normally break the glue joint. Most nuts are only held with a few dabs of glue or a very thin weak glue line at best.Hey all. Actually Muttley it's for the replacement tele...the action's been lowered but it could come down some more, I know it could. And there's a little ding in the nut, so I've decided fuck it I'll take it to someone who knows what they're doing. Depending on how easy it'd be to do, I might go for a new nut also. Here's the guy:
http://www.theguitarworkshop.net/
I'm sure I've passed on the "check your nut slot depth" tip to 30-20 in the past? Have you checked the string hight on this guitar? What action does it have now? What are you shooting for?
