F
fris9
I'm using a 2 overhead, kick, and snare mic setup to record, but I'm having trouble getting the snare to "pop" out of the mix. I've been told that I need to use compression on it and then give it a boost, but that brings up a new question. On my snare mic (sm57), i'm getting some bleed from the high hat, and a little from the toms. If I compress that mic, how will those bleed throughs affect the sound? One more question- do engineers delete noise between hits? Same with the kick drum. seems like a lot of work, but that it would clean up the bleeding, at least in between the hits on the kick or snare. Hope that makes sense.
