E
		ermghoti
Don't forget that the sm57 alone won't do it. Those "pro" recordings have killer pres, eqs and awesome compressors.
A very fair point. It is my understanding that a 57 benefits enormously from a decent pre.
Heavy guitars need mics that dont blur the low mids. You seem to be thinking that the upper mids will give you clarity, but this only works if the low mids remain under control.
Anyone got any suggestions for mics that work real good for recording distorted guitars?
Im looking to achieve a nice thick controlled low end, Nice clear high and high mids, but also Im looking for a mic that is good with getting very smooth high mids.
Cheers,
Eck
I think what he's getting at is that the 57 is really anything but flat in the upper mids from a frequency response perspective -- it's rather jagged and bumpy. At least that's my interperatation, and he's looking for something smoother and with less peaks in the upper mids -- correct me if I'm wrong.
Anything? I've used 57s, 58s, 91s, 609s, 421s, 121s, I5s, Cheap $50 condensers, CX112s, omnis, just about anything and have gotten a good sound.
I bet if I put a regular 57 and a transformerless 57 against the same amp in the same mix, your buddy hotapples couldn't tell the difference. Use what you have. If you want something new, get a 57 or an i5. If you can't get a good sound after that, something is wrong with you.
If it helps here is what it sounds like using an AKG D890 with a TubePre.
http://www.somnium7.com/samples/SOMNIUM7_vw-crazed_take-01.wav (2.9M)
That was raw take with no EQ or other processing. The guitar was a very old Gibson. Distortion from a Boss heavy metal pedal. The amp is some no-name piece of crap we found in a thrift shop for $20. I'm not liking the sound of the amp at all. The mic does a good enough job IMO.
Cheers everyone for the great responses.If its a multispeaker cab, damp it a bit with a packing blanket over a couple of the drivers.....It'll cut down on stray frequencies and damp the time delay of the unmic'd speaks hitting the mic diaphram.
Would be cool if you could post the 3 mic recordings.I plan to try my I5 out next time it's not busy on the snare. I think I will hook them all up and record three tracks for comparison.''
Good Luck.
F.S.
So yeah Im looking for a smooth yet present high mid range for my heavy guitars. (if that even makes any sense!)
I dunno, sounds pretty good to me. I would want to hear it in a mix to make a final judgment, but soloed, sounds pretty swell.
