M
Minion
Blow Me !!!
You could allways do what I am doing and Build your own Multi-Channel Mic pre-amp!!!
The one I am Building (Green Pre Older version) only costs about $50 per channel to build and has quality that Rivals Pre"s in the $1000 range (Or so I am Told) ....
You can also build your own DMP3 Clone which is actually quite a Bit easier than the Green Pre and it uses the Same Opamps as the DMP3 (INA163).....
If you have a Bit of elecrronix Knowledge and can read a schematic then it might be a Project to get into....
You can also buy a 2 Channel Mic Pre Kit from "PIIA" for about $75 that will be of better quality than Most Pre"s in the Sub $500 range per Channel....
Just a Thought!!!
Just a Thought!!!
