E
cellardweller said:That thing is SO NOT RED!!!![]()
That abomination is a disgrace to the good name of Fostex.
Besides, everyone knows that real men use compact flash EXCLUSIVELY!!!
I mix down on my CF and then bounce it directly to 8 track tape.
NOW GET WITH IT!!!
), and though it's been a while, I seem to remember a noticeable difference using my dmp3 as the track count increased.flyderman said:Hi, for the MR8HD users out there:
How important do you think is an external preamp needed with this machine? Assuming I'll be using at least one condenser which needs phantom power. I'm buying one soon, plus I have extra $$ (not much) and wondering whether to splurge it on extra mics or a preamp instead (say, a DMP3).
Thanks!
) which I use for external recordings and overdubs where instruments are hard to move (ever tried to fit an entire church organ together with all registers into a two-room apartment?). I like it primarily for the non-moving-parts recording capability. No moving parts = no mechanical sounds to block out.That's the specific reason I bought one ....... a cheap live recorder.YeshuasFan said:You forgot to mention that with the MR-8HD one can record 4 tracks at a time while one is limited to 2 tracks at a time with the MR-8.
ok, I finally found an important flaw in the MR8-HD. According to the manual:
" If you make recording or editing to a song many times, audio may be occasionally interrupted when the song is played back, due to data fragmentation. Note that this is not a malfunction."
I assume that this interruption will have no effect in tempo or bouncing since this will mean repeating recordings everytime there occurs an interruption.
also:
" When importing data from a personal computer to the MR-8HD, there is the danger that the MR-8HD file system may be destroyed. Especially, deleting or adding files many times may cause the fragmentation of FAT32, resulting in sound jump caused by performance deterioration. Therefore, before loading data from a personal computer to the MR-8HD, save all necessary folders to the personal computer and format the MR-8HD hard disk. "
Everytime I want to load a song into the MR-8HD I will have to format the internal disk for preventing errors ? and if have 30GB of data on the MR-8HD ?![]()
Thanks!
Is there any reliability advantage of a recorder that stores data on Compact Flash cards (CF) rather than on hard disk?
I'm grappling with the decision over MR-8MKII @ $249 versus the MR8 HD @ $399 or the MR8 HDCD @ $449. The latter two seem quite appealing because of the extra memory of 40GB and ability to record 4 tracks at once, unless there is a reliability issue that translates to CF cards being better.
Thanks.
Michael Y.
I've had an mr8hd too for a couple of years...
Great. It has paid itself back and then some. I use it for my home-recordings constantly, I've recorded a dozen live gigs with it, and drums on demos of two bands.
...now I want an mr16hd... because 4 simultanious inputs aren't enough..![]()
I have had the MR8HD/CD for about two years. never had a problem with recording, mostly at home,. It does what I need it for. Only problem I have with it is it won't make wave files so I can burn the CD. I get an error message and it completely distroys the recording files. Going to try to download into my PC and burn them there. I have had no help from Fostex, they just say to reformat the HD which does nothing. If I can't get it to work in the PC it's in the scrap can.
