Not that easy to get around on
A Reel Person said:
You and your wonderbox has now been obsoleted!
Meet: the Tascam X48 DAW!!
She really is a thing-O-beauty. Ain't she guys?
Ofcourse you know how much else you'll need to get this baby off the ground don't you?
Product Overview & Specs
Tascam X48 Hybrid Hard Disk Workstation
The X48 boasts 96kHz/24-bit recording across all 48 tracks and 192kHz across 24 tracks. Its file compatibility and synchronization surpass even the TEC Award-winning MX-2424, with Broadcast WAVE and OMF import and export for compatibility with workstations like Pro Tools®. Support for FireWire hard drives and Gigabit Ethernet allows simple transfer between systems, making it the ultimate multitrack solution for high-quality music, post and live recording applications.
Multitrack Recording Features
48-track digital recording at up to 96kHz/24-bit
24-track recording at 192kHz/24-bit
32-bit floating point audio file recording and playback with no loss of track count
Advanced integrated synchronization and machine control, including HDTV tri-level sync
Time-stamped Broadcast WAVE file format
Front-panel transport, track arming, project management and metering functions
Built-in 80GB hard drive
Built-in DVD+RW for backup, transfer and restore
±12.5% varispeed
Grid-style editing
Workstation/Mixing Features
Turn-key operation: no software conflicts to troubleshoot
Graphic user interface for editing, mixing, plug-ins and meters
48-channel mixing at 96kHz / 24 channels at 192kHz
32-bit floating point mixer resolution
6 stereo returns (60 inputs at mixdown)
24 busses, 6 aux sends, stereo master buss
Full dynamic automation
Dynamics, 4-band parametric EQ and 4 VST plug-in inserts per channel
Rear Panel Connections
48 TDIF Digital Inputs and Outputs
Stereo S/PDIF On and Out
(2) 24-channel option slots support analog, ADAT or AES/EBU expansion cards
BNC Video In and Thru, auto-terminating
BNC Word Clock In, Out and Thru, autoterminating
MIDI In and Out
TRS balanced 1/4" SMPTE In and Out
1/4" Footswitch Input
RS-422 (Sony 9-pin) Remote Input, also supports the RC-2424 remote
PS/2 Mouse and Keyboard Inputs
VGA Output
Gigabit Ethernet for FTP and drive sharing
4 USB ports for external hard drive support
2 FireWire ports for external hard drive expansion
Oh yea, Where's the six month night courses promised to purchasers to help them with the learning curve?
Screen, batteries and key pad not included
