Tom Overthere
Member
Helpful Pics, Excellent Timing
Thanks for the extra photos. Just in time, as my new belts arrived yesterday. Per your photos, that vinyl center fastener (my #1) appears to function as a bushing. Glad I know not to fool with it. Thanks.
Your last photo shows a truly like-new specimen. Still even has the sticky on the transport cover door. Impressive. Judging by your photo dates, Frigid February is "the time" for tearin' down the machinery.
Q1. What's the gray bottle at left-rear? A cleaner for the plastic, or an electrical contact cleaner? I need to clean the plastic surfaces really well before I reinstall the pot and fader caps, but don't want to risk marring/dulling the plastic surface with the wrong concoction. Any suggestions?
Q2. Also, I don't have contact cleaner on hand. If I re-assemble first, I can spray that stuff into the fader mechanisms past the slitted dust covers, right? Just affix the tiny spray tube to the nozzle and spray the length of the fader? Frankly, since the resale value is so questionable, I don't want to purchase $10 worth of cleaner that I'll likely only use this once. I have very little in the way of analog gear these days, and I don't recall there being any crackle in the faders...
Q3. Not sure how to test under present conditions whether my idler tires will work. With the unit disassembled (no bottom cover) I can't really set it on a table and pop in a tape. Need a third hand to hold the unit up on edge. No got, but I don't want to reassemble until I know the idler tires are good. Getting those knobs off was a PIA! So I don't want to go through that again.
Q4. I read about using laquer thinner to brighten up discolored (slightly yellowed) plastic transport control buttons. There's no way to remove those button surfaces from the top surface panel (they're plastic welded/riveted on). Any cautions with regard to laquer thinner and the dark surface around those buttons? Maybe just go lightly on the laquer thinner and control the rag to avoid surrounding dark plastic...?
