E
ericlingus
My setup is Schecter c1 xxx guitar - ubermetal distortion pedal(acting as a TS to tighten up the sound)- Mesa F50 combo - Boss GE7 - dual 57's (fredman technique) - Firebox - Cubse SX3. I recorded two separate takes panned 85 left and right and then another take with a differnt tone a variation on the riffs. Then copied and pasted it and panned hard left and right. All the takes had a DI'ed track going in too which I didnt end up using the way I intended(which was to add amp sim tracks). I just mixed the clean DI really low in the mix for more articulation.
I used EZ drummer with the DFH add on for the drums. I replaced the kick and snare though(well actually blended the DFH ones in slightly, just used the overheads and room mics). I used waves c4 on guitars and did the standard hi pass(60hz) and low pass(12k). I did some other eqing as well in the lows and low mids. I used the L3 over the whole mix.
That's about it. The playing isn't the tightest I know. I just kept the first takes. I was a little pressed for time. I also havent added in bass yet. I will the second time around after following whatever advice you give. Thanks guys!
..... I retried Rami's link and it worked okay in WMP. So I'm stumped....
