Zoom R16 and DAW
  • Thread starter Thread starter stevem5000
stevem5000
I record on a Zoom R16...8 tracks...
Right now I'm using Audacity to mix...very cumbersome and slow...
The Zoom is supposed to work with Cubase...but I just cannot figure Cubase out....I've gone thru videos...cubase help...forums etc...I can't do a dame thing in Cubase...
I do have "some" familiarity with Reaper...I can function very basically with it...
What I want to do...
Connect my R16 with USB to my PC....Open Reaper and set up my 8 tracks...then play the R16 into Reaper with Reaper recording....
Then I should be able to use my faders on the R16 to do a basic mix....at least that's how it's supposed to work using Cubase...
Then with Reaper I can render that to a stereo or mono file...
Can anyone talk me thru getting the R16 talking to Reaper...???
Be advised I am NOT very experienced with this equipment....I can do basic stuff...
Many thanks in advance for your time...
sounds like audacity would work better and easier for you if you cant figure out cubase
Mr Average...you have a good point...and my compliments to all those who can use Cubbase very well....just doesn't work for me...
Right now I have 7 tracks open in Reaper that I transferred from my R16 to my PC...and I can work with those...
I'm just looking for a little help getting the R16 to input into Reaper and record the tracks from there...
lets see now
audacity works but you say it is slow
cubase is too confusing
and you cant get tracks into reaper
why not try sonar its free
or one of the other free ones
else use what works
at least for now until you can figure out one you like better
I looked up the R16 whose specifications say "8-in/2-out USB audio interface for Macintosh/Windows computers". Presumably there will be installation instructions for setting it up as an interface.
Once that has been done, it is relatively straightforward to set up Reaper.
The steps would be:
1 Set the R16 as the input device for Reaper.
2 Create 8 tracks in Reaper, and set the inputs of these to be channels 1 to 8 respectively.
3 Then start recordng.
4 The next part is to set up the R16 as a control surface within Reaper. Someone else will need to advise on that because I don't use control surfaces. I work totally in the box.
There are two distinct workflows with R16 + DAW:
1. Record into standalone R16, import tracks to DAW for further processing + mixing
2. Record into DAW, using R16 as the audio interface (and control surface)
It's not entirely clear which one it is here, but talking about transfer sounds to me like 1). Sorry if this obvious, but for one, the R16 only works as a control surface in audio-interface mode, so you'll need to switch from transfer-mode to audio-interface after transfering to be able to use its sliders. And once there, you'll need to set it up as a Mackie control surface in the DAW, that's not going to happen automatically. I don't have experience with Reaper, but here's a fairly detailed walkthrough: Cockos Incorporated Forums - View Single Post - Zoom R16 as controller for Reaper
From memory, somebody gave me some files from his R16, and I loaded them in to Cubase one by one and all was fine.
The trouble with Cubase and all the others, to be honest, is that you've not given it time - they are all very similar and then very different in other ways. Cubase is sophisticated and complex, but the basic functions are very straightforward - IF you give it the time.
I've struggled with Cubase on and off for almost a year...went thru videos...PDF on how to do this and that....Cubase just doesn't make any sense to me...
I can do some stuff with Reaper...I got some good info from Turre....I think I can make this work...
Many thanks to all...
BTW if Audacity has been your first acquintance for working on audio on a computer, you'll want to unlearn most of what you learned there when moving to an actual DAW like Reaper, Cubase or whatever. Audacity is a fine piece of software for certain type of audio editing but the whole paradigm is entirely different and if you try to things the way you did it in Audacity, the DAW is going to fight back and appear confusing as hell because it's not the way they're supposed to be used. Been there :)
Turre...I expect you are correct...For a first timer getting into audio work....I found Audacity pretty easy...and I've learned that I can bring in 8 tracks and do a cumbersome job of editing...but it's slow...not as precise as I think things should be...I started out doing digital conversions from reel to reel and cassette...for this Audacity is just fine...but now that I'm recording in 8 track...I need something better....
I'm doing "barely ok" with Reaper...an awful lot to learn yet...but since my R16 is supposed to be able to be the front end for a DAW...it seems to me that things would be quicker and easier if I can use the R16 and at least
get my initial mix down quickly....
Thanks for the help...
R16 as the control surface wont do a whole lot to hide the DAW and its concepts from you.
May I ask you what sort of thing you're actually working on? Just thinking, if quick and easy are important qualities to get an initial mix-down then why not just mix on the R16 itself? Coming from a 4-track background myself, I discovered that involving computers in music-making killed both productivity and all the fun, and that despite its limitations (or perhaps because of them), sticking to the standalone R16 was far more productive than any DAW I tried. Of course, it all depends on your needs and if do you need to edit then the R16 doesn't have much to offer on that front.
We’ve been down that road of doubting why NOT to use a DAW before. Because it takes a little time to learn is not going to decrease your creativity once you learn it. I have an R16 that I originally used to record with. It’s a nice little unit but does not compare to any DAW out there. Mine is set up now as a control surface for Reaper and it works fine. I keep the inputs all connected to various things I use a lot and it’s quick and easy. The control surface is really convenient and keeps that old feeling of analog knobs and faders alive.
Well, each to their own.
Obviously the DAW enables things that simply are not possible otherwise and people like myself who are less enamored of them are in the minority these days, but the OP doesn't exactly come off as somebody who's in love with them. Hence the question.
Yup....I understand.....and I am certainly not trying to disparage anyone who wants to record and produce in any way they chose. But......three things in this case. The OP seemed to already have decided he wanted to try a DAW and seemed to have a good idea as to why he wanted to do that. And...since he already had the R16.....he likely well understood that he had the option of just using it alone to record if he wanted to. As well.........he was already asking about using the R16 as a control surface and was looking for increased ease for Reaper input.
I too was one who went from the 4 and 8 and 16 and 24 track digital units with knobs and faders and switches.............and I certainly hesitated long and often about going to a DAW........so I get where his trepidation comes from for sure....and I'm sure that you do too. It's at such times of hesitation that we often think the trouble of learning is not worth it and can be subject to doubts and excuses that serve to hold us back. My only concern was that the OP keep trying until he could decide for himself................after learning a DAW........whether or not it was worth it for him.
And....if I'm being 100% honest here........a while back we had a member who was VERY vocal about his preference for not using a DAW..........and he attacked and insulted many of us here for our positive views on DAW's. I am likely FAR too sensitive to that subject now......so please don't take any offense to my posts. You don't seem like that guy at all.
I'm somewhat partial to the recording decks. I really enjoyed working on my AW16G and AW1600 units, but moving files and managing projects isn't as easy as with the Zoom. I love being able to replace the SD card when I need to move to a different project. You can buy cards for $5 a pop which is less than I used to pay for 7" reels of tape back in the 70s.
I finally bought an 8 channel interface (Tascam 16x08) to connect to Reaper directly, but the majority of my recording has been in my Zoom R24. I have mixed some things on the Zoom, and have edited others in Reaper. I have yet do to any extensive recording through my interface. I want to do a comparison to the Tascam and Zoom preamps.
For me, having both techniques available is the best solution. The Zoom really shines when you are talking about live onsite recording. It's way less complicated than having an interface, and a computer. Plug a snake into the back and set up your mikes on the stage. Once levels get set, hit record and walk away. REALLY easy and foolproof.
If you need the flexibility of Reaper, its there. Best of both worlds!
I have a studio set-up, and a portable rig for live or off-site recordings. It is, as you say, easy and foolproof. But I use interface plus laptop. Plug snake into interface, set up mikes, set levels, hit record than you're off and running.
“The Zoom really shines when you are talking about live onsite recording.”
That’s for sure! If portability is part of your needs then the Zoom’s are excellent for that. Light weight and battery driven.....what could be better.
I used to transfer tracks from the Zoom to Reaper at first for editing and effects.....and then back to the Zoom for mixing. As I got better with Reaper........and began to understand the use of the Zoom as a control surface.......and how to record in Reaper.........it was just a natural step to record only in Reaper. I recently took the R16 to someone’s home to record them playing guitar and singing. He was interested in getting a Zoom for himself after that session. I encouraged him to do that. Where he goes beyond that is up to him.
If you use a Zoom16 or so, install the drivers and install the software, (I use Presonus), install the Zoom as a Mackie interface, set all up using this kind of interface. Then it works smooth and secure. Of course the in DAW software configuration is time consuming, as all settings and pre-sets are to be configured by choice and by hand, nothing is pre-installed. But once you have done this time consuming thing, it works great.
I used the r16 to record a live performance of our band using 8 ch.'s via the soundboard aux outs - sending (1) the drum mix (electric/acoustic mix on separate gear), (2) bass, (3) rhythm, (4) lead guitar, (5-8) vocals. All outputs were pre-fader and the gain/levels adjusted at the r16. After recording I sent the WAV files to my PC which gave me 4 sets worth of recording (approx. 3hrs) From here you can import them into any DAW to dissect them into individual song, or edit the set mix. I usually use audacity to cut the songs up - simply import the wave files set the trim points and then save them as audacity for further editing in audacity or wav for exporting into other DAW's. I've had good results with Sonar, FL Studios, and Reaper.
michielper
Replies
4
Views
10K
TalismanRich
TalismanRich
michielper
Replies
3
Views
9K
TalismanRich
TalismanRich
E
Replies
7
Views
1K
DrewPeterson7
DrewPeterson7
