T
This Is Poison
my drummer has broken COUNTLESS zildjian Z and A customs.
he is a pretty big guy though and we do tend to move a bit...
nope nope nope nope!iancl said:I've heard that all Paiste cymbals are sheet.
Sheet. All the cheap cymbals from all the companies are sheet.SpotlightKid83 said:what about sabian b8's??? cast or sheet??
You can get sabian aa and aax and other's cymbal packs.Farview said:Sheet. All the cheap cymbals from all the companies are sheet.
Rule of thumb: If the series comes in a discouted "cymbal pack" it's cheap shit stamped out of a sheet. Beginner cymbals.
Not discounted. Those aren't the ones that GC keeps blowing out for $110 every month.breeeeza said:You can get sabian aa and aax and other's cymbal packs.
breeeeza said:I can get a pieste alpha 18" rock crash ( which sounds perfect to me) for £100 but im afraid that it might break and paiste only give 12 months warranty where as the sabian aa metal x 18" crash whoich sounds damn good aswell is £152 but this comes with 3 yrs warranty i think. so..
breeeeza said:sabian aa or sabian aax cause i have heard that they dont break and you get 3 year warranty on them anyway.
All SABIAN cymbals are covered by a one(1) year warranty, except Hand-Hammered, HHX, and Artisan, which are covered for two(2) years. It should also be noted that All SABIAN cymbals and percussion purchased by an education institution are covered for two(2) years regardless of series.iancl said:I'm almost certain none of the big three offer more than 12 months.
Not necessarily. Generally sheet cymbals are less durable than cast because of an inherent characteristic of the molecular structure, but when well-made and well-played, sheet bronze cymbals can last as long as any cymbal.Blue Groove said:Brand has nothing to do with it. Sheet cymbals will break more easily than cast. Period.
breeeeza said:Do you know what the paiste alpha's are? Sheet or cast? Thanks
Sheet.SpotlightKid83 said:what about sabian b8's??? cast or sheet??
All Paiste cymbals and gongs are "sheet bronze"...made from discs cut by outside contractors. This includes the Signature and Traditional lines...all Paiste cymbals.TragikRemix said:sheet cymbals are all low end...paiste Signature, traditional, etc. are better 'cast' cymbals.
PYRRHO said:All Paiste cymbals and gongs are "sheet bronze"...made from discs cut by outside contractors. This includes the Signature and Traditional lines...all Paiste cymbals.
paiste.com faq said:How are Paiste cymbals produced?
1. middle of cymbal is fired
2. bell is pressed into the cymbal
3. cymbal receives a hole
4. disks entering firing oven
5. raw disk with bell and hole
6. pneumatic hand hammering
7. pneumatic hand hammering
8. hand hammering at anvil
9. lathing floor
10. hand lathing
11. checking shape during hammering
12. truing on level steel surface
13. shape control by hammering forema
14. checking thickness during lathing
15. brand name and model silk screening
16. edges are made smooth
17. testing production output
against master cymbals
We produce our cymbals today the same way we have for over half a century. Paiste's manufacturing philosophy is simple: we believe that only a human being has the intuition and abilities to create superior musical instruments. We allow the use of mechanical devices only where they remove strenuous labor from our instrument artisans, allowing them to concentrate their talents and energy on creating instruments of the highest sound quality and consistency. Any automation removing human control from the manufacturing process is strictly forbidden, as automation is counterproductive to a natural sound and our desire for top quality.
Beginning with the master cymbals carefully created by Sound Development, our production team then painstakingly works to craft exact copies of those master instruments. This ensures the ultimate in consistency and quality.
The majority of our cymbals are produced using Paiste's traditional production process. First the center of the cymbal is heated to soften the metal, then a bell is pressed into its middle. Some cymbals are sent through a high temperature oven in order to heat the entire disk. A hole is then punched through the center of the bell. (1-5)
The main production step involves the hammering of our cymbals by hand. To conserve the artisans' energy, we utilize a pneumatic hammering device in the initial shaping of the cymbal. At this stage the hammer operator has the ability to control velocity, force and other important parameters. The final shape corrections are then done by hand using only a hammer and anvil. (6-8)
Hand lathing with a sharp steel maintains the precise, correct thickness throughout the cymbal. Paiste's specifications do not allow for variations greater than a fraction of a hair's width (5/100 mm). (9-10)
Quality control procedures are implemented frequently throughout the production process. The precise shape of the cymbal is checked numerous times during production hammering. Great care is taken to balance the cymbal within itself by truing it on a precisely level steel surface. A micrometer is utilized during hand lathing to carefully control the instrument's thickness. (11-14)
The finishing touches are then applied by smoothing the cymbal's edges, stamping brand trademarks and model designations on the instrument and then coating it with a special protective solution to prevent oxidization. (15-16)
The final - and arguably most important - step in production is to hand test each and every finished cymbal against the master instruments produced by Sound Development. If a cymbal does not conform to Paiste's exacting standards, it is then destroyed. Only instruments of perfect quality and consistent sound character will be shipped and sold to our customers. (17)
TragikRemix said:so what is that telling us, are the sheet or cast?!?
OR both?
Not exactly...again Paiste takes it upon themselves to redefine widely accepted terms to better suit their manufacturing process. What they call "hand hammered", actually means... a hand-held pheumatic impact tool.TragikRemix said:so they are hand hammered sheet cymbals??
