Your process of recording vocals
  • Thread starter Thread starter MODROB
M
MODROB
Pro Tools setup.
Recording a vocal—what steps do you take? I don’t mean general singer tips, but from the microphone on in to the mix. I’ve struggled for years on finding what really works for me.
Let’s move past the mic please, and tell me what you do next—processing…compression, reverb…I want a fat, rich vocal sound, that’s “in your face” but effected with a dreamy, spacious verb that doesn’t sound like verb, but yet sounds suspended in the middle of a space with nothing around it. (Picture floating in that space above skies😉) Airy. (Forgot mention, slow song, solo vocal)
Anyone care to offer what works for you? Many thanks.
Tim
It's dependent of what the song is that the vocals go with - I use Compression, Gating, DeEssing and Plosive fillering, EQing, Spatial Plguins, and a host of other things -
as for your tracks - you need to post a track in order to hear what you are talking about.
Pro Tools setup.
Tim
There really isn't one one-size-fits-all approach here, so I'm not going to say "oh, here's my usual vocal process!" or anything like that - hell, mostly I record instrumentals. But, based on what you're describing, here are some approaches I'd be thinking about. Roughly in order of importance.
1) This should go without saying - get the best vocal performance you can. You want a pretty "effected" sound here, and you won't get that out of a raw vocal... but when you listen back to the raw vocal, it should sound great on its own, even if very dry and present and in your face. If the raw track doesn't sound great, you're going to struggle with everything else here.
2) "in your face" but still "fat and rich" - One thing I've done to "fatten" vocals in the past that had a lot of edge to them but less body is parallel compression. The easiest way to do this is to take your lead vocal track and make a copy of it on a new track. then, take that track, and absolutely smash it with either an aggressive compressor, or a limiter. Really overt, obvious compression, it shouldn't sound very nice on its own. Then, set the volume all the way off on your new track, hit playback, and slowly start bringing up the fader until your lead vocal starts to sound "thicker" and "fuller" more than "different." You'll still have the dynamic content of your original track, but with perceptibly more body to it. Then bus the two tracks together to a single bus to make volume management and subsequent processing easier in your mix.
2) a) You also might like the sound of some console or tape style saturation on, if not both, then at least the un-limited vocal, to add a little more edge and bite to your transients. Could sound great, could sound bad, you won't know until you try.
3) "In your face" and "floating" are not a common combo... but I'd suggest tackling this with a separate reverb/ambience bus rather than applying reverb directly to the vocal and adjusting the wet/dry mix. Especially if it's a stereo effect or panned to a different place in the stereo spectrum (and here's another could be crazy, could sound great approach - you could also use a pair of reverbs with different attack and decay times panned L and R to create more stereo image, while leaving your dry vocal in the center - I've never tried this but as I'm writing this i could see it being interesting). But basically, create a send from your dry vocal track, to a separate FX bus with a 100% wet spacious reverb effect on it, and then start with the mix very low and then bring it up until it's getting close to what you want.
4) Especially on a slower song don't rule out a bit of stereo delay, maybe a darker tape-style delay, mixed barely audibly on your vocal here. For bonus points you could try adding a delay somewhere in the FX chain on your reverb bus, too, so the echoes and reverbs are getting all mixed up with each other.
5) Also worth a try, and this is more of a longshot and would require a pretty good vocal - go full modern pop. A lot of pop production these days relies more on a "vocal stack" than a lead vocal, utilizing additional vocal lines in unison or harmony or a breathy soft vocal mirroring a more full throated one, etc sometimes throughout the song, sometimes selectively reinforcing a line or a word, etc. Get creative. If you've got a good vocalist and plenty of time on your hands, you could record a main vocal track and then a series of "reinforcement" takes, maybe selectively supporting the occasional line in your verses but coming out in force in the chorus, combining intensities and timbres. Super common in female pop these days, and if you want to hear a (much older) similar approach in a non-pop environment, Devin Townsend is just a vocal force of nature and while his own material has plenty of examples, I always thought his work on the chorus of Aeyron's "Day 3: Pain" off The Human Equation is one of the most incredible vocal performances I've ever heard - starts off with soft breathy harmonies for the first two lines, one of them jumps an octave and becomes full voice on the third, and the fourth suddenly you have death metal growls harmonizing with that same soft breathy voice and it's just, well, scary, how it does such an emotional 180. But, I think you might be able to go at thhis with a couple comlimentary tracks and get a lot of the "space" you want before you even reach for FX.
Pro Tools setup.
Tim
It has nothing to do with Pro tools. First to get that sound....you need an excellent microphone....such as one of the Chandler EMI mics (redd/Type L). Then the singer needs to be close to the microphone with a pop filter. I'm talking 3-4 inches....to get that detailed fat bottom proximity. Then EQ to flatter the vocal depending on the nature of the voice....and then good compression to bring out the detail 'even more'. That'll get you close.
You don't need an "excellent" mic to get great vocals. You also don't need to be 3-4 inches (!) from the mic. I mean, you can certainly get an excellent vocal from, say, an Aston mic, which will set you back about 200-300 bucks. I use Cad Equiteks, the 100 - 200 - 300-- I'd stack those against anything out there, but what do I know? Those mics, used (the original design Equiteks are no longer made), are avialable for well under 500 bucks on Ebay. That's all I've ever used, based upon rave reviews of those mics (and Aston mics too) and my personal experience, going back 15 years now. I don't use pop filters, and am back at least ten to twelve inches from the mic, though I do drift forward sometimes to about maybe 6 - 8 inches, and I have at least one artist who has a tendency to get closer than I'd like, but she's not a belter, so I don't use a pop filter on her, and it works. There's no need for a pop filter in that case, but of course, it depends on the singer and the style. If somebody is a screamer, or doing the cookie monster vocals, well sure, use a pop filter, but geting real close on a condenser seems like a bad idea generally. Here's a funny story: I read that Elvis Costello would get way too close to the very expensive condenser they were using to record his vocal back in the old days, and the spittle projected from his mouth actually shorted out the mic temporarily, and so they had to wait for the mic to "dry out" before they could do another take. Get close, shout, short the mic, try again. But they did get it done, so there you go.
Are you telling me or the Op? That was my suggestion to the Op and I stick by it. Yes humidity can do that to capsules, but when used with a pop filter mine is ok.
Sorry to be so long getting back here…
My thanks to those of you commenting, and I’ll be digging into the suggestions soon…
In the meantime, let me add this about my “search for the yellow brick road”…it just hit me that one thing I’m trying to “hear” is a vocal recording that sounds like it’s “not through a microphone” but so clear and pristine, as if it’s surrounded by vast space akin to outer space. 🤪 (that’s the vision that comes to my mind😉) I really need to find an example of what I think I’m “seeing/hearing” so maybe, just maybe, you can possibly understand my craziness. I’ll work on that too…😊
Pro Tools setup.
Tim
Hello to you, recording vocals is always a challenge in a home studio environment. Proximity effect is also a huge part of having a good vocal take or not. I'm a Logic Pro user and my audio interface is the UAD Apollo Twin x. Because of its virtual console, I have an 1176 compressor and a dynamic EQ on my vocal chain that is printed in my vocal track. My voice is a lot high/mid and harsh which gives me a challenge to mix every time because I'm hard on myself. I often feel that your body and mic placement will vary depending on the type of song you're recording. If you have clean levels on your vocal and it's not too harsh, EQ can be adjusted accordingly. Have a listen to one of my songs that I recorded, mixed and mastering was done by the famous Ian Shepherd.
So what is your mic of choice - one or more?
Hi, I'm using a SE X1A microphone that goes threw my UAD Apollo Twin X... Maybe this video from me on my channel will help
Thanks for the video - visuals always help.
I bought a pair of sE's VR2 active ribbons - love them.
wrong
wrong
total bullshit.
