Try not to overdo things.
Set limiter at -0.1 dB ceiling, fastest attack, and treshold around -2dB; play with release time from 0.1 ms to 10 ms to keep transparency.
Think about it as a safety net, you can mix 2-3 dB louder.
Then you can set compressor ( before limiter ) to compress overall
dinamic range. It depends on music type which amount of compresion you will need. For acoustic jazz, bigger amount of compression ( gain reduction around 5-6 dB ) will smooth overall sound, and increase loudness.
For rock or metal, gain reduction bigger than 2-3 dB will cause breathing and pumping.
Generally, try attack around 20-30 ms to pass transient peaks ( and keep high end ), fastest release time, and ratio between 2:1 - 4:1, soft knee.
