WhiteStrat
Don't stare at the eye.
Guitar ideas:
Double track-electric or acoustic: (I'm sure you know this one) don't bother duplicating and panning the same track-it doesn't do anything. Actually play and record it twice, panning one left and panning one right. I often go 100% L and 100% right, but play around with it.
Double track with 2 mics--electric (if you have 2 different enough mics): I'll record a guitar with 2 contrasting mics (a ribbon-dark and smooth) an i5 (bright and edgy). Then I play the same part and record it again. Now I match up the ribbon from take one and the i5 from take 2 and send 'em left. Then the i5 from take one and the ribbon from take 2 go to the right. Now with just 2 takes you have an even fuller sound.
Octave double tracks-electric or acoustic: either of the above but with take one and take two played at different parts of the neck (i.e. open chords on one; A string bar chords on the second). Lots of texture there.
Pick track--electric: If you've got two mics, put one of em on the amp like normal, and put one of 'em up on the hand of the guitarist. The further from the amp, the better, so you're just getting that clicky pick sound. Mix this track with the regular amp track to add some attack and dynamics to the guitar part.
Got a bright Chinese condenser mic that sounds like crap on your amp? Put your dynamic mic up on the amp like normal, and use the bright condenser up in the middle of the room. Cut the low on the room mic track and just use it for reverb or delay plugs; some cool sounds there.
It really puts some things in to perspective; like all the time I spent fretting over what kind of snare mic to use, or why I can't seem to EQ it to sound right and all that. I mean ... this guy is hitting his snare and it sounds like a finished record, right now, over my monitors, and I haven't done jack shit but point a mic at it. As encouraging as it all was ... It was also kind of a let-down to realize just how insignificant my role truly is in the grand scheme of things. And how much time I had wasted on other things up to that point.
