1
1021
Yorkville Audiopro 3400 power amplifier is designed and built to provide
years of trouble free performance.
The AUDIOPRO 3400 weighs a comfortable but solid 42 pounds, fits into two
rack spaces, runs at near digital efficiency, reproduces music with over 4000 Watts of headroom, draws all the power it needs from a standard AC outlet, and has excellent distortion and noise specifications. It will drive reactive, phase shifted loads with no difficulty
HUM AND NOISE: -105 dB below max output RMS voltage, unweighted.
DC OFFSET: Less than 25 millivolts.
PROTECTION: Fully protected: DC, LOAD and THERMAL.
COOLING: Interleaved heatsink with DC servo controlled fan.
SLEW RATE: Power amp: 30 V/usec, 60 V/usec in bridged mode.
(rise time limited to 18 V/usec by input filter).
DAMPING FACTOR: > 500, 20 Hz - 400 Hz, into 8 ohms.
MAX OUTPUT CURRENT:
100 amperes for 10 milliseconds, 50 amperes contin.
TURN ON/OFF: < 15 milliwatt / seconds, 0.5 Wpk. (1s on delay)
EFFICIENCY: Better than 75% at full power into 4 Ohms.
WEIGHT: 42 pounds. 17.75 Kilograms.
SIZE: 3.5" x 19" x 15.75 (front panel to binding posts)
POWER SUPPLY: Toroidal transformer and combination
power switch/circuit breaker.
POWER CONSUMPTION:
Will not exceed 13.5 Amps under actual conditions
Due to the age, the amplifier it is being sold AS IS.
I'm asking $400.00 + Shipping
Please email me for pictures, local pickup prefer
musicproaudioequipment@gmail.com
MAX OUTPUT CURRENT:
POWER CONSUMPTION:
