1
		1021
Crown D-75 amp + Yorkville Studio Monitors Series YSM1 in great working condition. Price $249.00
The D-75 are perfect for moderate power applications such as recording or broadcast studio near-field monitoring, video suite audio monitoring, a recording/broadcast headphone amp or a small paging system.
Designed, built and carefully checked to ensure reliable operation with a wide variety of loads, Crown D Series amplifiers are convection cooled. Their high reliability is particularly important in reducing maintenance costs.
Specifications
Output Power per Channel in Stereo Mode with Both Channels Driven: FTC Continuous Average Power from 20 Hz to 20 kHz with No More than 0.1% THD -75A: 35 watts into 8 ohms, 45 watts into 4 ohms. Maximum Average Power at 1 kHz with No More than 0.1% THD: D-75A: 25 watts into 16 ohms, 40 watts into 8 ohms, 55 watts into 4 ohms. Output Power in Bridge-Mono Mode: Maximum Average Power at 1 kHz with No More than 0.1% THD: D-75A: 110 watts into 8 ohms. Signal-to-Noise Ratio (unweighted): 106 dB below full rated power from 20 Hz to 20 kHz. Input Impedance: 20 K ohms balanced, 10 K ohms unbalanced. Controls: Power, channel 1 and 2 detented level controls, dual/mono jumper. Connectors: Inputs: Balanced three-pin Neutrik combination XLR and 1/4-in. phone jack for each channel. Output: Four-terminal barrier block (two per channel) and stereo headphone jack. AC Line: Standard three-wire grounded connector. Dimensions: 19 in. (48.3 cm) standard rack mount width, 1.75 in. (4.4 cm) height, 8.38 in. (21.6 cm) depth behind mounting surface. Net Weight: D-45: 9 lbs. 11 oz. (3.9 kg). D-75A: 9 lbs. 7 oz. (4.3 kg).Shipping Weight: D-45: 10 lbs. 9 oz (4.8 kg). D-75A: 11 lbs. 4 oz. (5.1 kg).Total Harmonic Distortion (THD): Less than 0.001% from 20 Hz to 400 Hz and increasing linearly to 0.05% at 20 kHz delivering rated power into 8 ohms/channel.Intermodulation Distortion (IMD): (60 Hz and 7 kHz 4:1) Less than 0.05% from 0.01 to 0.25 watt and less than 0.01% from 0.25 watts to rated power into 8 ohms/channel.Load Impedance: Rated for 4 to 16 ohms in Stereo and 8 to 16 ohms in Bridge-Mono. Safe with all types of loads.
YSM1 - Passive Monitor - 70w, 6.5 inch / 1 inch
The YSM-1 is a compact, 2-way, near-field studio monitor designed to accurately reproduce the signal from a recording and mixing chain without contributing sonic coloration. It has clarity and bass response that you would expect to hear from a much larger cabinet and is suitable for Home and project-studio recording as well as sound reinforcement applications. "It reproduces timbres with near pinpoint accuracy"¹. and produces pristine sound which defines the finest details and harmonics of the input signal.
System Type2-Way Active or Passive Program Power (Watts)70
Nominal Impedance (Ohms)6
Sensitivity (dB @1Watt/1m)90 Frequency Response (Hz +/- 3db)40-20,000
Crossover Frequency (Hz)2,500
Driver Configuration1 inch, 6.5 inch HF Driver(s)1 inch Soft (Silk) Dome - Medium Viscosity Ferrofluid Cooled LF Driver(s)6.5 inch Foam Surround Sheilding
Inputs1 Inputs - Binding Post1 Enclosure MaterialsMDF Wood Baffle MaterialMDF Wood Port(s)Tuned 2 inch Cylindrical GrilleBlack Cloth Covering / FinishBlack Woodgrain or White Laminate
Dimensions (DWH xbackW, inches)9x10x16
Dimensions (DWH xbackW, cm)23x25x41 Weight (lbs/kg)18/8
This system it is being sold AS IS.
Please email me for pictures, local pickup prefer(too heavy to be shipped ), I accept cash on the pickup
I will be donating the money to Toronto Humane Society
musicproaudioequipment@gmail.com
Specifications
-75A: 35 watts into 8 ohms, 45 watts into 4 ohms. Maximum Average Power at 1 kHz with No More than 0.1% THD: D-75A: 25 watts into 16 ohms, 40 watts into 8 ohms, 55 watts into 4 ohms. Output Power in Bridge-Mono Mode: Maximum Average Power at 1 kHz with No More than 0.1% THD: D-75A: 110 watts into 8 ohms. Signal-to-Noise Ratio (unweighted): 106 dB below full rated power from 20 Hz to 20 kHz. Input Impedance: 20 K ohms balanced, 10 K ohms unbalanced. Controls: Power, channel 1 and 2 detented level controls, dual/mono jumper. Connectors: Inputs: Balanced three-pin Neutrik combination XLR and 1/4-in. phone jack for each channel. Output: Four-terminal barrier block (two per channel) and stereo headphone jack. AC Line: Standard three-wire grounded connector. Dimensions: 19 in. (48.3 cm) standard rack mount width, 1.75 in. (4.4 cm) height, 8.38 in. (21.6 cm) depth behind mounting surface. Net Weight: D-45: 9 lbs. 11 oz. (3.9 kg). D-75A: 9 lbs. 7 oz. (4.3 kg).Shipping Weight: D-45: 10 lbs. 9 oz (4.8 kg). D-75A: 11 lbs. 4 oz. (5.1 kg).Total Harmonic Distortion (THD): Less than 0.001% from 20 Hz to 400 Hz and increasing linearly to 0.05% at 20 kHz delivering rated power into 8 ohms/channel.Intermodulation Distortion (IMD): (60 Hz and 7 kHz 4:1) Less than 0.05% from 0.01 to 0.25 watt and less than 0.01% from 0.25 watts to rated power into 8 ohms/channel.Load Impedance: Rated for 4 to 16 ohms in Stereo and 8 to 16 ohms in Bridge-Mono. Safe with all types of loads.Studio Monitors Series
