peritus
The not fountain head
JeffLancaster said:Actually yes, I have read that it's not the best idea to have your mix position in the exact center of the room. However, I do believe it's a good idea to have yourself, as well as your monitors, positioned evenly between the sides of the room. I have also read that when using nearfields you don't want them positioned TOO close to either the back or side walls as that will tend to exagerate bass frequencies. The manual for my monitors recommends at least a foot from any walls.
Your room seems to be quite similar in size and shape to mine, (mine is about 14 1/2 feet long by 8 1/2 feet wide) so I'll tell you what's working pretty good for me. I have the back of my desk positioned about 18" from the front wall. Since the legs of my desk are also equipment racks, this gives me just enough space to get behind there and run cables, etc. The furthest back points of my monitors end up being about 20" inches from the front wall and they get no closer than 14" from either side. When sitting in the ideal mix position where my head and monitors form an equilateral triangle, my ears are approximately 5'10" from the front wall (approximately 40% back into the room). I have 2" acoustic foam on the front and side walls as well as the on the ceiling for the front 6' of the room. This seems to really control early reflections that could bounce off the sides or the ceiling of the room. The backwall of my studio I left bare, and I have foam bass traps in all four corners. This arrangement really works great, although one area I think I could improve upon would be adding more substantial bass traps in the back corners of my room (behind my mix position), probably something along the lines of the Ethan Winer bass trap design.
Hope that helps...Jeff
Great info.. Thanks
What part of the room do you record in?
