canadianrocker
I've connected an external sequencer to play back the internal voices of the P-90. I have everything connected properly, and starting the sequencer plays back the sound on the P-90, but it will only play the Factory Setting Grand Piano 1 voice. Changing the voice on the Voice Buttons doesn't change the playback voice, or changing the reverb or effect doesn't change anything - only the Transpose changes - nor does changing any of the Midi settings in the function on the P-90 or on the sending sequencer.
Is there any way to play different voices on the P-90 from an external sequencer? Or do you have to select a voice, record that voice to the sequencer, and the sequencer will only play back whatever voice it was recorded with? Page 29 of the manual shows how to change a voice setting for the internal recorder, would this work for an external sequencer as well? Is there any way to assign the internal voices to a specific Midi channel? ex. Grand Piano 1 on Midi channel 1, Voice on Midi channel 8, etc.
