I'm on the fence about upgrading to a Mackie Onyx 1220 to a 1620, or buying the Yamaha n12 instead. The 1620 would be a deal since I already have a Mackie 1220 with Firewire--just have to unload the old mixer on Ebay and swap the Firewire card into the new 1620.
But from what I'm reading, the pres in the n12 may be superior to the Mackie's. I also like the software integration, built-in reverb, comp, and the idea of mixing down OTB on the n12. The Mackie only sends two channels back to the mixer, so everything must be mixed ITB. Also, the Mackie recording outs are Pre-Insert, Pre-EQ, Pre-Mute, Pre-Fader--that is, dry only.
But what about aux sends? Don't you need extra aux sends to supply different monitor mixes--say to the drummer, singer, guitarist? The Mackie 1620 has four aux sends (which may be adequate). But it also has analog outs for each channel, meaning you could even set up a separate physical monitor mixer if needed. But even on the Mackie, you can't solo the aux channels .
The n12 has what, ONE aux send and no analog channel outs?
Am I missing something here? Is there any way to create more than one monitor mix on the n12 (even if more hardware is required)?
