willovercome
i want to hook up two sets of speakers to two different sound cards. but each card only has one set of main outputs. should i just use y-spliters, or will the sound levels drop too much? is there another way to do this?
What you may want to look at doing here would be to create a wire that would hook the output of your MIDI card up to an auxiliary input on your sound card, that way you could use you sound card's mixer to mix the audio for you. I did this with my brother's computer because he has a Dolby 5.1 card but the recording was horrible, so he uses 1 card to record and 1 to play back, but there was no way for him to monitor while recording. We soldered a wire onto the line out of his recording card and plugged it into an aux. in on his Dolby card and it works like a charm.willovercome said:no i won't. i just want to have both set hooked up so i can listen through them seperatly without having to switch any cables around. the reason i need to do this is because i have one card that only does my midi, and another that only does my audio. but, if the signals will still be strong enough to use, then i'll just go the way of the y-spliter.
