rob aylestone
Anyone familiar with the routing on these. I want to set a pair up in a particular way that seems to not be possible. I want to have an X32 on stage, operating basically as a fixed item that simply takes the sound sources own stage and splits them to the P16 monitor system. The other 32 is front of house and it's output comes out of the M32 stage box the two mixers are connected to. What I want is for the primary mixer to be the stage one, but not have any outputs connected, the Foh mixer is the number 2 mixer. If I want the audio from the Foh mixer to come out of the M32 stage box then it seems to have too be the primary mixer, with the monitor desk syncing to the digital A line. Sometimes, we use splits - for festivals now, and don't want the Foh mixer at all - we just sniff the stage sources and run our p16s, but to do this involves unplugging network cables and swapping them and then changing sync to internal. I want to have the stage mixer connected to the M32 permanently and the Foh as secondary- which is perfectly possible - BUT - and here's the problem, I cannot seem to route the Foh mixers output to the outputs on the M32 stage box - these seem to always link to the mixer designated as the sync source.
I want the Foh mixer to be the optional one, but when it's wired, to use the outputs on the M32. This doesn't seem to be possible.
