D
djelf
HI, I am having a little trouble, and have tried to no avail to fix it. I am using Sonar to boost and eq some of our shows that were recorded on minidisc.
1. I can't get my MOTU to give a sensible (i.e. not all messed up) signal to Sonar. it's all garbly. so i'm stuck with soundblaster.
2. every minidisc goes into sonar, i can listen to it, and it's fine. there were a couple loud peaks that sounded like static or something on one recording, but it did play through it. however, when I export to .wav and burn with Nero, the buffer gets all used up at some point and it says there is a write error. once was on that static-y clip, and other times it is at a crescendo it seems ( i normalize, and have tried lowering 3db from normalization, could clipping create a data glitch?). i tried cutting the offending section, but the glitch just stayed, only a half second earlier. the cd plays fine to the error, then repeats the preceding five secs up to the error for the rest of the disc.
i do get usable tracks, but it sucks not being able to burn a certain song cause of this. is it just cause of the minidisc format? any tips/suggestions?
one more thing, what is that kind of scratchy, almost dirty vinyl needle sound that comes every 3/4 sec or so sometimes when I burn discs? I play it in my cd player, and some songs have it, some don't...
